Which tie down straps do you use?
#1134348
12/15/11 03:07 AM
12/15/11 03:07 AM
Posts: 28,071 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I'm looking for a good set of axle straps to tie down a race car. They will be used on a sprint car and possibly a full steel road race car.
There's some serious cheap garbage out there as well as some overpriced stuff.
What do you guys use when dragging your race car around?
Re: Which tie down straps do you use?
[Re: 604 Hemi GTX]
#1134351
12/15/11 09:57 AM
12/15/11 09:57 AM
Bought mine from summit,they sell them as a kit 4 tie downs and 4 axle straps. http://www.summitracing.com/parts/CMB-29-0012/ Never had a problem and there not the cheap ones. Kevin
I use those also. I don't like that they are so stiff. I use them up front with the military ones out back on my open trailer. If I had a choice I'd try and get another set of military ones.
[Re: feets]
#1134352
12/15/11 10:48 AM
12/15/11 10:48 AM
Challenger 1
Cincinnati, Ohio
I'd look around and see if there are any businesses near you that sells truck tie downs. I've used the Summit tie downs and didn't like the stretch I was getting. Took them to a local truck place that makes them to have them rewebbed. They replaced this hardware... The new hardware didn't have the sharp edges.
