Re: brake pedal to floor space after full braking on e body
[Re: roadrunninMark]
#1133494
12/13/11 08:42 PM
12/13/11 08:42 PM
RapidRobert
Alot of alum M/C's have a thinner flange and or the piston is closer to the flange both of which effect a higher pedal. Either the adapter plate which I'm assuming is already in use or yes a shorter pushrod (there are diff lengths) or an adjustable one. You could machine a spacer plate (of the desired thickness) to go between the firewall and the alum 2 to 4 hole adapter to space the M/C and adapter farther forward to lower the pedal. I'm assuming the pushrod/retainer is locked in far enough to be in the machined recess in the piston EDIT Not sure I'd trust just a weld but I'd be comfortable with cutting the p rod to shorten it then sliding the ends into a hardened double female sleeve then welding each end. That'd be the simplest/cheapest way to go
#1133498
12/13/11 10:43 PM
12/13/11 10:43 PM
RapidRobert
Sounds like you're spot on & more spacer will fix it
