Re: Can't stop stat housing leak [Re: RapidRobert] #113292
09/01/08 10:56 PM
09/01/08 10:56 PM
Orleans, Ontario
moparcanuk Offline OP
Orleans, Ontario
Where in the stat exactly would you drill this hole?
Re: Can't stop stat housing leak [Re: moparcanuk] #113293
09/01/08 11:01 PM
09/01/08 11:01 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Anywhere on the outer edge.
Re: Can't stop stat housing leak [Re: moparcanuk] #113294
09/01/08 11:04 PM
09/01/08 11:04 PM
USA IN
E85-408 Offline
E85-408  Offline
USA IN
Only thing that has worked for me was an OEM or a aftermarket with a recess cut into it for the thermostat. I wipe it all down with acetone and use alittle gasket maker on both sides then bolt it down and let it sit over night. Learned my lesson too many times from not letting it sit long enough for the gasket maker too cure.
Re: Can't stop stat housing leak [Re: moparcanuk] #113295
09/01/08 11:06 PM
09/01/08 11:06 PM
united kingdom
Simonic Offline
Simonic  Offline
united kingdom
I don't think it really matters.
I installed a new stat this year and it came with a hole drilled in already in the centre section
Keeping the Bee Buzzin'
