How much gain from a cold air system?
#1130320
12/09/11 02:17 AM
12/09/11 02:17 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
My car has uncoated headers and tends to get pretty dang hot under the hood. How much performance gains could be seen from grabbing air from outside the engine compartment?
Re: How much gain from a cold air system?
[Re: StealthWedge67]
#1130324
12/09/11 08:59 AM
12/09/11 08:59 AM
Posts: 10,020 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Good rule of thumb is 1 percent hp for every 11 degrees reduction. So a lot depends on how the air is flowing to your carb before the cold air intake is added. Another important item is the carb entry. A well radiused aircleaner base is important, and stay away from the lids that have filters in them. From a really bad setup to the best possible you could pick up .3 or so, between lid, base, and cold air. It is a system. If what you have is pretty good, might not see much over .1.
[Re: tboomer]
#1130327
12/09/11 02:51 PM
12/09/11 02:51 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
We gained almost 5mph and went from 10.42 at 127.8 to 10.21 at 132mph....
Holy crap!! On what car,if I may ask?
Yea really ! Ron
[Re: BradH]
#1130331
12/09/11 07:01 PM
12/09/11 07:01 PM
StealthWedge67
Puyallup, WA
I wouldn't be adding a hood scoop, I'd be drawing from the fenderwells through the caster / camber adjust holes, with a sealed system. My current setup is pretty low budget. Its just a 14" drop base with a 3" element, which makes for a narrow pinch point inside the assembly. This coupled with the choke horn on the primary side of the carb makes for what seems like a somewhat restrictive setup that is sucking in hot air. Sounds like most people see at least some gains, I think this mod will be in the works for the winter; along with milling the choke horn off, and maybe moving my battery to the trunk. Thanks guys
[Re: Dragula]
#1130333
12/09/11 08:32 PM
12/09/11 08:32 PM
Posts: 4,055 Salina ks
572_dup2
Back On The Bumper!!
Salina ks
With my 2x4s after i added the crazy scoop on top of what i had i picked up nearly 4mph.
Shawn Jennings
#1130334
12/09/11 08:54 PM
12/09/11 08:54 PM
Posts: 7,664 IN
ahy
IN
Thanks guys
If you move the battery you can pick up cool air from the battery vent most models have... may be easier than the adjust holes.
[Re: schreecher]
#1130339
12/14/11 01:26 PM
12/14/11 01:26 PM
Posts: 17,914 S.E. Michigan
ZIPPY
S.E. Michigan
I picked up 3 tenths and 3mph. It was the most impressive low buck improvement I ever made.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#1130341
12/14/11 03:06 PM
12/14/11 03:06 PM
Posts: 996 Queens, New York
Harley
Queens, New York
Same here!
[Re: Harley]
#1130342
12/14/11 04:06 PM
12/14/11 04:06 PM
Posts: 3,210 robin hood country
deaks
robin hood country
Can some of you show pics from the engine bay please, i have a big opening under my Hemi scoop, so not sure how to go about this. Sorry about the hijack. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
