Throttle cable bracket for Indy intake #1130170
12/08/11 08:24 PM
12/08/11 08:24 PM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
I almost have my new motor ready to start but my throttle bracket I was using on my M1 intake is a couple of inches too short. What are you guys using on your Indy small block intake? Pictures would be nice if you have any. Thanks for any help....
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Throttle cable bracket for Indy intake [Re: D-50] #1130171
12/08/11 08:48 PM
12/08/11 08:48 PM
AndyF Online content
AndyF  Online Content
Indy sells a tall throttle bracket which is designed to work with their small block intakes.
Re: Throttle cable bracket for Indy intake [Re: D-50] #1130172
12/08/11 08:51 PM
12/08/11 08:51 PM
Q
Quicktree Offline
Quicktree  Offline
Q
jegs bracket
Re: Throttle cable bracket for Indy intake [Re: D-50] #1130173
12/08/11 10:36 PM
12/08/11 10:36 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
mine is from hughes performance,works perfect
Re: Throttle cable bracket for Indy intake [Re: fishy340] #1130174
12/09/11 01:25 AM
12/09/11 01:25 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
home made, fits any manifold.
Re: Throttle cable bracket for Indy intake [Re: Quicktree] #1130175
12/09/11 01:32 AM
12/09/11 01:32 AM
ONTARIO,CANADA
604 Hemi GTX Offline
ONTARIO,CANADA
jegs bracket I used the jegs bracket and a throttle cable from a dodge truck with a slant 6.
Re: Throttle cable bracket for Indy intake [Re: Quicktree] #1130176
12/09/11 01:53 AM
12/09/11 01:53 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Tony do you have a P/N for you upper and lower radiator
hoses.... they look like they would be perfect for
my ride
thanks
Re: Throttle cable bracket for Indy intake [Re: MR_P_BODY] #1130177
12/09/11 06:31 AM
12/09/11 06:31 AM
Q
Quicktree Offline
Quicktree  Offline
Q
my ride
thanks
I think so, I'll look this afternoon.
Re: Throttle cable bracket for Indy intake [Re: D-50] #1130178
12/09/11 01:28 PM
12/09/11 01:28 PM
Here is the Indy SB throttle bracket. They also have a matching throttle return kit.
Re: Throttle cable bracket for Indy intake [Re: AndyF] #1130179
12/09/11 02:46 PM
12/09/11 02:46 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I know mine is not a smallblock but it works the same. As I used this Lokor setup. I like the fact that with their cable that you cut to the lenth you need you just bolt the bracket to the rear carb stud so you dont need any special throttle cable bracket. Course I know you have to use the Lokar cable and not a stock cable but it is a simple setup. Ron
