Modifying a cast 383 intake? #1130058
12/08/11 06:43 PM
12/08/11 06:43 PM
NH
torredcuda Offline OP
NH
`70 383 road runner being biult as a nice driver/occasional strip car.I have a fairly mild combo- 9.5-1,torquer cam(don`t have specs here) To look stock I plan on running the stock intake and exhaust manifolds and factory equipped Holley 4160 carb.It has a 727 and 3.23 gears behind it but a gear swap for track days is easily done with the 8 3/4 rear.What I am looking for is how to modify the plenum area for my combo and are there any other mods I can do like gasket matching etc.Extrude hone is out due to budget.
Re: Modifying a cast 383 intake? [Re: torredcuda] #1130059
12/08/11 06:46 PM
12/08/11 06:46 PM
Florida STAYcation
dOc ! Online penguin-006
The village idiot's idiot
dOc !  Online Penguin-006
Florida STAYcation
WHY NOT just a better alum intake ? Ex-Hone is so over-priced for the bennies ...
Re: Modifying a cast 383 intake? [Re: torredcuda] #1130060
12/08/11 06:48 PM
12/08/11 06:48 PM
dogdays Offline
dogdays  Offline
Call Brzezinski Racing and ask them. They do a lot of cast iron work and are pretty helpful on the phone.
Is there an Edelbrock 383 intake that has a Mopar part number? You can always grind off the Edelbrock script. It all looks the same under the paint!
R.
Re: Modifying a cast 383 intake? [Re: dOc !] #1130061
12/08/11 06:48 PM
12/08/11 06:48 PM
NH
NH
Let`s see -I said I wanted to LOOK STOCK and cannot AFFORD extrude hone!!! Please read and try to comprehend a post.
Re: Modifying a cast 383 intake? [Re: torredcuda] #1130062
12/08/11 06:52 PM
12/08/11 06:52 PM
Florida STAYcation
Florida STAYcation
Well let's see ...if you can't afford EH ... then you can't afford any aftermarket service providers. And you can get many alum intakes that LOOK ENUFF STOCK ....
..ORE ...get a better paying job so you can afford EH ..
Re: Modifying a cast 383 intake? [Re: dOc !] #1130063
12/08/11 06:55 PM
12/08/11 06:55 PM
NH
NH
I can modify the intake myself for the cost of a carbide and some sand paper drums or take it over to my buddy with a machine shop and have him do it for free.I plainly said I wanted to use the factory intake, I don`t know how to explain it any better???
Re: Modifying a cast 383 intake? [Re: torredcuda] #1130064
12/08/11 07:00 PM
12/08/11 07:00 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
I think they did comprehend your post, they're just trying to save you some hard work and headaches, some of the older Edelbrock intakes look stock once they are painted and the script is ground off, also the M1 dual plane looks stock, I think it even has the firing order on it. None the less, you could cut the divider out of your cast intake to open up the plenum volume, and just your basic port and polish, round off any sharp turns and mildly increase the volume. It is said that the later cast iron intakes used on the 400's are a better intake so maybe you should start with that. They are a spreadbore design so you would have to make an adapter to fit the 4160 to it and open up the primary side so there is no interference with the primaries hitting the intake. That's what I had to do when I put a 4160 on a 360 spreadbore intake, I made an adapter out of 1" thick aluminum plate, and had to mill/grind out the primary side so the primaries wouldn't hit.
Maybe some of the FAST guys will chime in because they are the experts on making the cast intakes work, although I can't recall anyone using a single 4bbl on a Mopar BB in FAST, but I'm sure there are some.
Re: Modifying a cast 383 intake? [Re: torredcuda] #1130065
12/08/11 07:01 PM
12/08/11 07:01 PM
Florida STAYcation
Florida STAYcation
On a mild combo like you have ... I think what you are trying to do is wasted effort. I did the whole-ball-of-wax on a 440 TQ iron intake some time ago ...
I would have gotten better results doing something else .....LIKE ..
those exhaust mans .... now THERE you will see improvements.
Re: Modifying a cast 383 intake? [Re: torredcuda] #1130066
12/08/11 07:05 PM
12/08/11 07:05 PM
NH
NH
Re: Modifying a cast 383 intake? [Re: torredcuda] #1130067
12/08/11 07:05 PM
12/08/11 07:05 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I did a 340 and 383, you need a extra long style port kit. Then the porting is just common sense, lot of work and mess for MAYBE 3HP. Google porting, you should be able to comprehend it.
Re: Modifying a cast 383 intake? [Re: ademon] #1130068
12/08/11 09:11 PM
12/08/11 09:11 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
To be honest if it were me I would leave the intake and exhaust manifolds off the table and spend the effort somewhere more meaningful,like the cylinder heads. You have to understand that when you monkey with the divider wall you are messing with the bottom end and with a stock stroke 383 with 3.23 gears that would be the last thing I would look at. A big engine with alot of stroke can hack it and you need to kill the bottom end.
You are about to go down a path that is labor intensive and filthy dirty all for something you butt may or may not notice. I would look elsewhere
Re: Modifying a cast 383 intake? [Re: torredcuda] #1130069
12/08/11 11:34 PM
12/08/11 11:34 PM
Minn
SportF Offline
SportF  Offline
Minn
Years ago in '68 I opened up the 4 individual holes in a stock '63 Dodge 383 and made an open plenum. Put it on and ran the whole summer with it. When I put a two barrel carb and manifold back on it for the winter I found that to have much more performance than the 4 barrel, seat of the pants kind of performance gain. I threw the modified 4 barrel away, it was a dog. I'd watch what you do, it didn't work out for me.
Re: Modifying a cast 383 intake? [Re: SportF] #1130070
12/09/11 11:09 AM
12/09/11 11:09 AM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
I have to agree with Tom on this. I would do nothing more than a good inlet tract port matching. The engineers were pretty good at what they did back then. Most of the Chrysler intakes are quite efficient as is for a stock type application. Any meaningful modifications cost a small fortune.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: Modifying a cast 383 intake? [Re: scatpacktom] #1130071
12/09/11 12:08 PM
12/09/11 12:08 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
well said, good advice.
Re: Modifying a cast 383 intake? [Re: torredcuda] #1130072
12/09/11 12:56 PM
12/09/11 12:56 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Jeff , I sent you a PM.
But I have to agree, the work that was done to that intake in the link is on a +500" motor that needs to kill some bottom end so the tires don't go up in smoke.
If you want it to LOOK stock you could find an old M1 dual plane, it's a copy of the 666 intake only in aluminum.
The stock intake has 4 runners with acute angle turns I can't imagine how that works out well ??? but the engineers must have knew something ?
Re: Modifying a cast 383 intake? [Re: WO23Coronet] #1130073
12/09/11 01:01 PM
12/09/11 01:01 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
NONE of the Edlebrock intakes look stock when painted, they are somewhat close but they don't have the choke stove mount and the coil is relocated so a holley wit ha dual feed line can be used. I have a DP4B which would be the best ebrock intake for the low deck.
Re: Modifying a cast 383 intake? [Re: torredcuda] #1130074
12/09/11 01:38 PM
12/09/11 01:38 PM
Idaho
LaRoy Engines Offline
Idaho
A stock intake manifold can be used. But how much flow does it actually leave on the table?
I tested a 906 head flowing 321 cfm @ .700" lift. Here is what happened.
Test (1), ported 906 by itself
Test (2), ported 906, 1968-69 383 manifold 2806301, port matched and mildly plenum blended & 4401S AVS
Test (3), ported 906, box stock 383 Victor intake, 4401S AVS
Lift........(1)...........(2)...........(3)
.100........71............69............69
.200.......150...........131...........143
.300.......209...........172...........203
.400.......257...........187...........234
.500.......292...........199...........259
.600.......313...........203...........273
.700.......321...........204...........273
With a good intake manifold you can get the same flow at .300" lift as you can with a port matched and plenum blended stock manifold at .600" and .700" lift. Start changing carburetors and the flows increase even more.
Re: Modifying a cast 383 intake? [Re: LaRoy Engines] #1130075
12/09/11 01:50 PM
12/09/11 01:50 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Hey Old Guy, your the man!!!!!!!!!!!
Getting old just means you were smarter than some and luckier than others.
Re: Modifying a cast 383 intake? [Re: dannysbee] #1130076
12/09/11 02:11 PM
12/09/11 02:11 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
a 340 intake with about 25 hours in it. all of it done at my work on the clock, would not attempt another one on my time!!
Re: Modifying a cast 383 intake? [Re: ademon] #1130077
12/09/11 02:11 PM
12/09/11 02:11 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
2nd
