Re: MSD-5 Install Qustions
[Re: mikemee1331]
#1127541
12/18/11 08:52 PM
12/18/11 08:52 PM
Posts: 5,443 Indiana
YO7_A66
Indiana
I have not tried a standard light but the motor runs like crapt above 1600rpms. If it is just the light, then it will still run like crapt above 1600rpms even with anoter light. This is why I think that the timing is advancing too much causing it to run like this. My hight idle (1400rpms) was showing 60 degrees so I am guessing that it is in the low-mid 60's at 1600rpms. I will try and track down a standard light to rule that out.
What if there is enough differences between the FBO box and the MSD box and the 54 degrees that I am seeing is actually correct? I did not move the distributor during this swap and I assumed that I would not have to just in a box swap. What if I am wrong about that? You did talk me into swapping the wires and I am glad that you did. I think that I had the wires wrong on the new connector that I added and I had electrical tape covering them so I did not see it before today. I will check my alternator wires.
Thank you both.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: YO7_A66]
#1127542
12/18/11 09:00 PM
12/18/11 09:00 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I have not tried a standard light but the motor runs like crapt above 1600rpms. If it is just the light, then it will still run like crapt above 1600rpms. This is why I think that the timing is advancing too much causing it to run like this. I will try and track down a standard light. What if there is enough differences between the FBO box and the MSD box and the 54 degrees that I am seeing is actually correct? I did not move the distributor during this swap and I assumed that I would not have to just in a box swap. What if I am wrong about that? You did talk me into swapping the wires and I am glad that you did. I think that I had the wires wrong on the new connector that I added and I had electrical tape covering them so I did not see it before today. I will check my alternator wires.
Thank you both.
For the time being... look at this as 2 separate problems... fix the timing then go back to the gauge issue... the gauge issue could be as simple as a voltage regulator or a diode in the alt
[Re: MR_P_BODY]
#1127543
12/18/11 09:12 PM
12/18/11 09:12 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
Thank you both.
good , sound advice! no, there should not be any jump in timing just because you changed ECU. what happens with the wrong timing light is multiple flickers which makes it appear like your balancer is slipping. or you get nothing at all. now if you try solid core spark plug wires, watch out! it looks like a disco ballroom down there!
[Re: mikemee1331]
#1127544
12/18/11 09:21 PM
12/18/11 09:21 PM
YO7_A66
Indiana
I am using Firecore wires so I assume that these are good. Maybe the voltage issue is what is causing the engine to run poorly the higher I rev it?
I may pull the alternator and the voltage regulator and have them tested. But I will check the wiring to both first. thanks
[Re: YO7_A66]
#1127545
12/18/11 09:29 PM
12/18/11 09:29 PM
MR_P_BODY
I think of it the other way... too high of timing will cause it to break up at higher revs OR its starting to cross fire... get the timing set at about 34 to 36 degrees total(and you shouldnt need 25 initial) about 16-18 then the rest with mechanical then more with vac for cruising
[Re: MR_P_BODY]
#1127546
12/18/11 09:39 PM
12/18/11 09:39 PM
YO7_A66
Indiana
Mr P: I believe that you wrote that this is the light that you are currently using? http://www.summitracing.com/parts/FLA-FR1001/ I am going to return my second dial back and if this is a known good timing light, then I will swap my current unit for this one. Thanks
[Re: mikemee1331]
#1127548
12/18/11 10:58 PM
12/18/11 10:58 PM
YO7_A66
Indiana
Mike, No offence taken. The engine ran perfect before the ECU swap so I am assuming that my issues are from my own wiring or from the MSD box installation. The last ECU was not reliable and I chose this box. I will check the wires around the alternator and trace them back to the firewall to see if there are any issues. Maybe another timing light will give me some insight on the timing. What is weird is the ammeter bouncing around. It did not do this before the ECU swap. I am wondering if the box is doing something that is making the ammeter and the volt gauges act up.
Thanks again.
[Re: YO7_A66]
#1127549
12/18/11 11:33 PM
12/18/11 11:33 PM
MR_P_BODY
Yes thats the light I use now days and of all the lights I own I like that one best... just slide it over the wire and your done
[Re: MR_P_BODY]
#1127550
12/19/11 08:36 AM
12/19/11 08:36 AM
YO7_A66
Indiana
I ordered that light and some timing tape. In a few days I will be able to confirm the timing. Thanks Mr P. Tonight I plan on checking the wiring on the alternator to make sure something has not come loose.
[Re: mikemee1331]
#1127552
12/19/11 09:35 PM
12/19/11 09:35 PM
YO7_A66
Indiana
I was checking my alternator wires and I found that the field wire connector for the two dark blue wires was loose enough to move back and forth. I found that the mounting screw for the male stud came loose so I grabbed my screwdriver and snugged it up. A couple of weeks ago I was moving the heater hoses around and I must have snugged up the alternator harness too tight and once the engine started idling it must have pulled on that electrical connector and loosened it up. I moved the harness and tightened it up so it will not move against the wire connectors. I also cut off both of the field wire original electrical terminals because they were old and loose and I replaced them both. HOPEFULLY this will yeild some good results on my ammeter/gauge issues. I have the heavy red wire going to the positive battery cable and the heavy black wire going to the negative battery cable. The 12v MSD wire is fed from my dark blue RUN and the tan CRANK wire and my ""volt gauge is also spliced into this area"". If the volt gauge is going to cause an issue, then I will just pull it out. I rerouted the MSD coil wires up to the cowl just to get them away from everything electrical for testing. I ran out of time tonight so I did not get to start it up. I might have my new timing light tomorrow or Wednesday and then I will check the timing again. Thanks a bunch everyone and I have my fingers crossed.
[Re: YO7_A66]
#1127553
12/19/11 10:35 PM
12/19/11 10:35 PM
mikemee1331
bethlehem pa
The 12v MSD wire is fed from my dark blue RUN and the tan CRANK wire and my volt gauge is also spliced into this area.
hmmmmm................
[Re: mikemee1331]
#1127554
12/19/11 10:48 PM
12/19/11 10:48 PM
YO7_A66
Indiana
I asked the MSD tech about having the volt gauge wired in there and he said that it would not be affected by the box. I hope that I can keep it wired up but I am not sure yet.
My plan is that the next time I start up the car and I still have the gauges going crazy, I will disconnect this volt gauge to see if the ammeter and the battery voltage gauge clear up.
[Re: mikemee1331]
#1127556
12/20/11 09:47 PM
12/20/11 09:47 PM
YO7_A66
Indiana
My heavy red wire is on the positive battery cable. Thanks. I have an UPDATE: I swapped the distributor wires (again) and I used my new advanced light (Thanks Mr. P) and I now have good initial timing again. It showed 22 degrees with the new light. So the ECU swap to the MSD only changed by 2 degrees. COOL!! Thank you all for your patience on that one. ---------------------------------------------- Even though I found the loose connector at the altenator, my ammeter is still bouncing around at idle the same as before (just left of straight up to the middle of the +). But, the two voltage gages are now showing 14v +/- 1/2 volt. So the volt gages cleaned up allot (still jumping at idle rpms from 13.5 to about 14.5) but still not as solid as before. At 1400rpms the ammeter and both guages are solid. Note: After I was done, I shut the car off and put the battery charger on the battery and it started at 75% and went to 100% within a minute or two. Any suggestions on the electrical issue? Thanks again for your patience.
[Re: YO7_A66]
#1127557
12/20/11 09:55 PM
12/20/11 09:55 PM
MR_P_BODY
Change your regulator
[Re: MR_P_BODY]
#1127558
12/21/11 08:45 AM
12/21/11 08:45 AM
YO7_A66
Indiana
I will swap that out. Thanks again.
[Re: YO7_A66]
#1127559
12/21/11 07:11 PM
12/21/11 07:11 PM
mikemee1331
bethlehem pa
sweet! now i don't feel like a D-bag for tell you how great MSD ign's are
