'65 383 Discovered
#1126940
12/04/11 12:33 AM
12/04/11 12:33 AM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
I ran across a 383 in a garage. It has "A383" and "5 4" stamped on the top of the block. The number on the side is 2468130-3 with a date of what looks like 4.28.85 but it has to be 4.28.65. It has a two barrel intake with a Stromburg carb. It has 2406516-8 heads. The brackets and cross member all look like 1965 era stuff but the carb is throwing me off. I am suspect the block and heads are nothing special but what about the carb? Any thoughts on the whole deal? BTW, it also has a 727 (I think) bolted to it.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
Re: '65 383 Discovered
[Re: dfsmopars]
#1126941
12/04/11 01:31 AM
12/04/11 01:31 AM
RapidRobert
My 1967 "glenns" manual shows a '65 361/383 to be sporting a wwc-3 stromberg and a '65 361/383 could also have a carter BBD (a 2bbl) EDIT not sure if the stromburg is a 2 or a 4bbl
[Re: dfsmopars]
#1126945
12/04/11 04:14 PM
12/04/11 04:14 PM
dfsmopars
Kentucky
My son went yesterday and picked up the unit and has it in his garage. I'll have him take some pictures of it in the critical places and I'll post them. I just think that there is something different about this engine because the guy that had it was a GM man and I doubt he would have had it taking up space if it was worthless. He was a body man that had restored quite a few GMs.
[Re: dfsmopars]
#1126946
12/05/11 12:10 PM
12/05/11 12:10 PM
Posts: 74,978 U.S.S.A.
JohnRR
U.S.S.A.
Don't hold your breath thinking that.
It's a 2bbl 383 , nothing more , nothing less ...
[Re: dfsmopars]
#1126950
12/06/11 11:00 PM
12/06/11 11:00 PM
dfsmopars
Kentucky
So what are the three cables coming out of the transmission? One is the speedo, one is probably for the shifter but what is the third one? The question is more to satisfy my curiosity. The tranny will be going in the classified section soon. The rest of the story is, the engine was part of the negotiations in the purchase of an original '53 Chevy sedan. The seller would not agree to the offer we made but did agree to throw in the 383 and tranny.
[Re: Cab_Burge]
#1126953
12/07/11 02:47 AM
12/07/11 02:47 AM
RapidRobert
slip yoke or b/t. please say b/t so I dont shoot you an offer
[Re: G-40RCE]
#1126955
12/07/11 10:13 AM
12/07/11 10:13 AM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
That trans has a front and rear pump You can tow it any where without disconnecting the drive shaft.
You can also push start it!
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
[Re: dogdays]
#1126957
12/07/11 05:59 PM
12/07/11 05:59 PM
Rug_Trucker
I would port the 516's, add hardened seats and run them. They have some nice looking chambers.
