440 oiling mod question #1126591
12/03/11 07:33 AM
12/03/11 07:33 AM
Ohio
fiddlestix Offline OP
Ohio
I have drilled the #2,3,4,5 main oil passages out to 9/32" like the tech archives say to do. My question is why shouldn't the #1 main be drilled? Or should it be? Thanks guys!
Re: 440 oiling mod question [Re: fiddlestix] #1126592
12/03/11 09:02 AM
12/03/11 09:02 AM
SW Ohio
AAR-B4 Offline
AAR-B4  Offline
SW Ohio
I don't think the #1 main oil feed needs to be larger since it is fed directly from the main passage from the pump leading to the lifter gallies. The #1 main is the first exit for the oil system.
That said, it's not a problem if it's opened, the correct bearing clearance will maintain the needed volume for the remaining exits.
Re: 440 oiling mod question [Re: AAR-B4] #1126593
12/03/11 10:21 AM
12/03/11 10:21 AM
Lost in Pooler, GA
Gumbydammit Offline
Gumbydammit  Offline
Lost in Pooler, GA
Just curious, how did you drill it? Did you use a ream or a drill bit? Hand drill?
I'm Gumby dammit!
Re: 440 oiling mod question [Re: Gumbydammit] #1126594
12/03/11 10:22 AM
12/03/11 10:22 AM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
I have used both a drill bit and a reamer with a pistol drill.
I have drilled the #1 also ...
Re: 440 oiling mod question [Re: JohnRR] #1126595
12/03/11 12:12 PM
12/03/11 12:12 PM
Ohio
Ohio
I used a drill bit. I would rather use a reamer but didn't have one.
