Re: Hole in my foot project here
[Re: 70440+6bbl]
#1125703
08/19/13 09:40 AM
08/19/13 09:40 AM
Posts: 3,060 Western New York
sixpackbee
Western New York
Did you end up building the numbers engine, or a big inch monster that you mentioned in the beginning of the thread?
James, The engine/trans that was in the car is tucked away safely. This one is +.030 Ross piston, Ohio I beam rod, stock crank all balanced. 452 heads with some mild bowl work and SSI valves. Comp Cams custom hydraulic, Smith pushrods, Isky rockers and Lunati springs. I fiddled with the trans a bit. Since he decided to keep the 4.10's I put a little bit of a converter in it. We are taking it to the track to see what it will do. I think some mid 13's are in order. I can't stand to see restored cars running 16's like you see so often.
1959 Bugeye Sprite 1967 Charger Black L code 1967 Coronet R/T Convert Green 440 auto bought from original owner 1968 Charger R/T Bronze 440 4 spd console AM/FM 1969 Super Bee WM21H B5 A40 D21 N96 1969 Barracuda Formula S 340 Convert pilot car 1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85 1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96 1970 Road Runner RM21N B3 V1X D13 1971 MG Midget 1971 Road Runner RM23H GW3, A57 1972 Road Runner RM23P FY1, D21
[Re: sixpackbee]
#1125705
09/11/13 11:41 AM
09/11/13 11:41 AM
sixpackbee
Western New York
Not much to post in the way of pictures. Been doing wiring and dash work. Not exactly thrilling photo subjects. Got the master done and the booster dolled up and installed. All the brake/fuel lines run. Headliner in. All the little things that take up an unreal amount of time but really look like they should not. Back at it I suppose.
[Re: sixpackbee]
#1125707
10/28/13 09:05 PM
10/28/13 09:05 PM
sixpackbee
Western New York
Got the engine running. First time in 30+ years there has been heat in there. Need a few things yet. Tan cap, new vacuum advance can, pit free master cover ect.
[Re: aspenrt360]
#1125711
10/29/13 11:47 AM
10/29/13 11:47 AM
sixpackbee
Western New York
Keep the original in a safe place and get a repop for the car. If anyone gripes tell them the original is rusty and fragile and is safe place and that the repop is an exact copy.
[Re: basketcase]
#1125713
10/29/13 09:53 PM
10/29/13 09:53 PM
Posts: 5,268 NY
70440+6bbl
NY
beautiful work! what is the tin piece with the fender tag?
It's an inspector tag.
From my '69 Swinger
