Ram 4.7 Ticking Lifters Sludge and Engine Flush
#1124908
12/01/11 11:15 AM
12/01/11 11:15 AM
Posts: 299 East Brunswick, NJ
finadk
East Brunswick, NJ
I have an 02 Ram Pickup with a 4.7, 115k miles on it and owned since new. It has had regular oil changes every 3-4k. at about 80k it developed a valve lifter tick. Sounded like a diesel in the morning. Took it to the dealer and they said that my 2 mile drive to the train station every day was not enough to sufficiently warm it up and it developed sludge. I let them perform an "engine flush" (which I thought was total BS) and WOW it came back running better and the lifter tick went away after about 500 miles.
Well now a few years later the valve lifter noises have come back. Does anyone know what a dodge dealer would have used to do the engine flush? My local dodge dealer closed down and Id like to do it myself. I tried Seafoam in the crank case for 100 miles then changing the oil but that just seems to have pissed it off and made it louder.
Any input is appreciated. Scott
Scott
1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed)
2002 Dodge Ram 1500 Quad Cab
1976 Corvette
Re: Ram 4.7 Ticking Lifters Sludge and Engine Flush
[Re: finadk]
#1124909
12/01/11 11:47 AM
12/01/11 11:47 AM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Go to your local dollar store and ask for a quart of transmission oil run it for a while, get it good and hot, then change the oil and filter. Or try engine oil flush. I beleive Gumout makes a good product. Do Not leave this in there. Follow the instructions on the package. In the future, take it out for a good run at free way speeds, about once a week. This will help keep it clean.
I have mechanical Aptitude. I can screw up anything.
[Re: 493RT]
#1124915
12/02/11 10:28 AM
12/02/11 10:28 AM
Posts: 52,972 Romeo MI
MR_P_BODY
How long do you leave the trans. fluid in ?. Let it idle or can you do some driving ?.
I drive it like normal... if its sludged up bad I run a qt for a day or 2 before a oil change but if I've had a problem engine I run a qt all the time
