leafspring car goes 4.48@169 sheesh!
#1124782
12/01/11 02:36 AM
12/01/11 02:36 AM
Posts: 1,404 Chesterfield Twp. Mi.
John Burdine
Brandon Fugler's 69 Camero 4.48 @ 169 3100 lbs Leaf springs No anti roll bar Naiser built 622 Mfi on alcohol/Procharger 315 radials without beadlocks now, where are the guys that say you must have lots of front suspension travel for a Caltrack car to work!
Re: leafspring car goes 4.48@169 sheesh!
[Re: joshking440]
#1124785
12/01/11 02:45 AM
12/01/11 02:45 AM
John Burdine
John I saw that car run in Georgia and it was insane. I couldn' beIieve it. I bet I walked over and looked at it 10 times I bet.
Front left tire never touches the track
get any good looks under the rear of the car? anything special to see?
[Re: racerx]
#1124794
12/01/11 01:32 PM
12/01/11 01:32 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Is there any rule that says a mopar cant put in a longer leaf spring?
the shorter leaf was an advantage back in the day
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: John Burdine]
#1124795
12/01/11 02:09 PM
12/01/11 02:09 PM
Posts: 1,491 Oologah, Oklahoma
Big Squeeze
Oologah, Oklahoma
Here I am.......When guys say they need a lot of travel to work, they're talking about the typical car out at the track that doesn't have near that kind of power and I'm sure is heavier in the front than that car (no radiator)........ plus, I'm certain, track conditions were really good when he ran that number.........If he were running on the typical weekend bracket race track he'd need more travel to get it off the starting line too.......
Like mentioned, there are FAST cars going 9's now without Caltracs......
If you can't handle the truth, you're living a lie.......
[Re: Quicktree]
#1124797
12/01/11 02:58 PM
12/01/11 02:58 PM
Posts: 728 mi usa
old yeller
mi usa
you put enough controllable HP to any kind of suspension you can go fast. I think the F.A.S.T. cars have proved that.
Bingo!
[Re: Mr.Yuck]
#1124801
12/01/11 05:35 PM
12/01/11 05:35 PM
John Burdine
While technically that is a "leaf spring" car, it's far from a stock suspention. As mentioned the FAST guys are in the 9's w/ SS Springs.
would you rather see more 4 bar mustangs?
