67 Coronet turn signals??? #1124240
11/29/11 06:46 PM
11/29/11 06:46 PM
Pittsfield, Mass.
Russ_Davis Offline OP
Pittsfield, Mass.
All work except right front. Parking and flashers work. Bulb is good. Where to look for problem.
Re: 67 Coronet turn signals??? [Re: Russ_Davis] #1124241
11/29/11 08:47 PM
11/29/11 08:47 PM
PA
moparboy66 Offline
moparboy66  Offline
PA
Maybe this will help...
Re: 67 Coronet turn signals??? [Re: Russ_Davis] #1124242
11/29/11 08:48 PM
11/29/11 08:48 PM
PA
moparboy66 Offline
moparboy66  Offline
PA
and this...
Re: 67 Coronet turn signals??? [Re: Russ_Davis] #1124243
11/29/11 08:58 PM
11/29/11 08:58 PM
Right front flasher works? If so that's the same large filament in the 1157 dual bulb as the RF turn signal & from the bulkhead forward you are OK. I'd seperate the dangling TS/brake pull apart electrical connector under the steering column with the TS stalk "up" I'd check continuity on the col half & need continuity on the hot wire "in" up to the TS switch and "out" on 2 wires (1) to RF and (1) to RR turn signal large filaments. If flashers dont work on RF holler back
Re: 67 Coronet turn signals??? [Re: RapidRobert] #1124244
11/29/11 09:16 PM
11/29/11 09:16 PM
Pittsfield, Mass.
Pittsfield, Mass.
Right front flasher works.
Re: 67 Coronet turn signals??? [Re: Russ_Davis] #1124245
11/30/11 03:58 AM
11/30/11 03:58 AM
Sure looking like TS sw/harness. Split the pull apart connector & see what you get for continuity & holler back when you can
