another weight question #1123692
11/28/11 09:09 PM
11/28/11 09:09 PM
Aubrey, Texas
O
oldtimer5151 Offline OP
O
Aubrey, Texas
With the driver in the car, I have the car on the scales and wondered if the final setting should have equal weight setting on both back tires?
Re: another weight question [Re: oldtimer5151] #1123693
11/28/11 09:22 PM
11/28/11 09:22 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
yes as a starting point. some add 25-35 lb preload on right rear but all cars are different and it might takwe more or less to keep it straight
home of the
Sox and Martin Hemi Duster
Re: another weight question [Re: oldtimer5151] #1123694
11/28/11 10:53 PM
11/28/11 10:53 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Next time out to the track see if it goes to the
right on the launch... if so ADD some preload to the
right rear tire
Re: another weight question [Re: MR_P_BODY] #1123695
11/29/11 12:53 AM
11/29/11 12:53 AM
Aubrey, Texas
O
O
Aubrey, Texas
I have the l/f about 1/2inch taller than the r/f. The car has a 48/52 ratio. The left or right rear is about 25# more on the right. I guess I might be close. Thanks
