Torsion bars/ride height? stock suspension #1122801
11/28/11 12:48 AM
11/28/11 12:48 AM
Great Lakes State
O
ONEBADBIRD Offline OP
O
Great Lakes State
On a 69' Road Runner I was told you can adjust the ride height (on the front end/lower or higher) with the torsion bars? If not is there a way to adjust the ride height on stock suspension? Thanks, Jay
Re: Torsion bars/ride height? stock suspension [Re: ONEBADBIRD] #1122802
11/28/11 12:52 AM
11/28/11 12:52 AM
PA
68_CONV_300 Offline
68_CONV_300  Offline
PA
correct you can adjust the tension on the torsion bars with the adjustment stud in the lower control arm
Re: Torsion bars/ride height? stock suspension [Re: ONEBADBIRD] #1122803
11/28/11 12:59 AM
11/28/11 12:59 AM
MR_P_BODY Offline
MR_P_BODY  Offline
yes you can, like was said at the lower control arm,
just spray them with penetrating oil a couple of days...
you will need a front end alignment if you move
it much
Re: Torsion bars/ride height? stock suspension [Re: ONEBADBIRD] #1122804
11/28/11 01:00 AM
11/28/11 01:00 AM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
Yes, front end height is easily adjustable on all Mopars with torsion bar suspensions. I assume from your question that you must be new to classic Mopars. There is an adjusting bolt [ 3/4 in. head size ]at the bottom of the lower control arms of your car. Turn clockwise to raise the height and counter clockwise to lower. If they haven't been used for some time I would soak the threads with penetrating oil for a day or so before turning them. Ride height MUST be set before doing front end alignments. You can make MINOR [ + or - 1/4 inch ]changes to the height without affecting the alignment to any great extent.
Re: Torsion bars/ride height? stock suspension [Re: MR_P_BODY] #1122805
11/28/11 01:04 AM
11/28/11 01:04 AM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Yup, 3/4" deep socket and the longest bar ya got, CW to raise, CCW to lower, absolute minimum clearance at lower arm / bumper 1/2" on billiard-table roads.
