Re: 40-over rings on 30-over pistons ? ...
[Re: dOc !]
#1122161
11/27/11 01:21 AM
11/27/11 01:21 AM
RapidRobert
Yes 10 over is the max (& will work fine) otherwise they'll be slightly oval even w the gap filed down (which you do also w the 10 overs) if you use more than 10 over. Do check the oil ring tension & crimp the expander "links" in a bit if needed. the oil ring top/bottom rails always have adequate clearance
[Re: dOc !]
#1122162
11/27/11 01:36 AM
11/27/11 01:36 AM
Posts: 52,972 Romeo MI
MR_P_BODY
... a Bud asked me this .. just curious what some have done.
Its gonna have a ton of ring drag
[Re: MR_P_BODY]
#1122163
11/27/11 01:55 AM
11/27/11 01:55 AM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
I agree. It would work,but won't be "correct". Even with a .010 over ring,they will be oval,just not as bad as a bigger size would. Stock rebuild maybe,but not in a performance application. Keith
[Re: MoparforLife]
#1122166
11/27/11 05:33 PM
11/27/11 05:33 PM
Posts: 30,474 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
It can be done but I know that I would want to be careful on having adequate ring gap. Squeezing that ring down may close the gap a little tight. Too little ring gap can get nasty.
Oh I hear you on ring gap ... and that would mean checking gap on ALL 32 rings .. not just the top 8 rings.
[Re: dOc !]
#1122169
11/27/11 09:10 PM
11/27/11 09:10 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
... maybe it is considered "ONE RING" but there are TWO oil-rings in that one groove in each piston.
If you want to be a smart A$$ about it call it 3 That would make it 40 ring set (5 rings to a piston) - wouldn't it. You may have fun with the expander but-------- I for one have never heard of it your way but then I am new to the game.
