Re: u- joint tool [Re: therocks] #112075
09/02/08 03:22 PM
09/02/08 03:22 PM
Seattle, WA
rss Offline
rss  Offline
Seattle, WA
I recently bought the Harbor Freight tool mentioned in the first response to this post.
It worked like a charm and was cheaper than buying an 8" vise just to replace u-joints. My 6" vise was too small.
The u-joints I removed had been in the car at least 20 years and beating on them with a hammer wasn't getting me anywhere. I figured I was probably just going to damage the ears on the drive shaft.
Re: u- joint tool [Re: rss] #112076
09/02/08 10:28 PM
09/02/08 10:28 PM
Bowie, MD
Reggie Offline
Reggie  Offline
Bowie, MD
If a vise isn't handy, a large C-clamp and assorted old sockets also work like a charm.
Re: u- joint tool [Re: Reggie] #112077
09/03/08 12:41 PM
09/03/08 12:41 PM
Seattle, WA
rss Offline
rss  Offline
Seattle, WA
I tried the c-clamp method as well, but mine were so stuck the c-clamp started to deform.
The Harbor Freight tool is basically nothing but a REALLY beefy c-clamp with a threaded rod sized for a 1-inch socket. I had to use a breaker bar on mine to push the old joints out.
Re: u- joint tool [Re: rss] #112078
09/03/08 12:48 PM
09/03/08 12:48 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I take them out with a hammer and put them in with the c clamp. Works fine for me. Mike
Re: u- joint tool [Re: rss] #112079
09/06/08 12:52 AM
09/06/08 12:52 AM
Chilly Northern, Minn.
71 Charger R/T Offline
Quote: I figured I was probably just going to damage the ears on the drive shaft.
I remove and install with a hammer.
You're more apt to damage the ears on the yoke with a vice or a press than a hammer.... I learned how easy and superior it is to do it this way when I worked in a driveline shop. The only thing I use the vice for is to support the yoke , shaft or joint between the jaws while knocking out the joint. Just make sure you hammer on the weld yoke and not the driveshaft tube! I've seen SO many driveshaft yokes ruined by people using presses and vices and just forcing the caps in!
Re: u- joint tool [Re: 71 Charger R/T] #112080
09/06/08 10:24 AM
09/06/08 10:24 AM
when you get the new one in it must turn free & you need to be able to rock it back & forth with your hand.lay the shaft on the ground with a socket under the ear on the bottom & rap the ear on top just behind the ujoint cap with a BFH then flip it 180 & do the other.2 or 3 times each side. Frees them up perfectly.
Re: u- joint tool [Re: RapidRobert] #112081
09/06/08 11:37 AM
09/06/08 11:37 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
