68 - 70 B BODY DANA DIFFERENCES #1119930
11/23/11 06:28 PM
11/23/11 06:28 PM
fresno ca
mikeysmopars Offline OP
fresno ca
I need help Identifying the differences in 68 to 70 b body dana 60.
What are the obvious differences? breaks, Emergency Break Cable, Part Number locations. I have a 70 gtx I need one for and have severl friends that I can get one from but want to make sure of application. Any pictures and help is appreciated.
Thanks in advance!
Founder and CEO of the Central Valley Mopar Drag Pack
Re: 68 - 70 B BODY DANA DIFFERENCES [Re: mikeysmopars] #1119931
11/23/11 07:24 PM
11/23/11 07:24 PM
A Banana Republic near you.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
Thanks in advance!
If it has BREAKS you want to find one that is not broken.
That aside , the part number is stamped on the right side avle tube towards the center , the brake backing plates are the same , the drums may be different 68/69 vs. 70 , the E brake cables are the same , 68 will have a drain plug in the bottom of the housing.
Re: 68 - 70 B BODY DANA DIFFERENCES [Re: JohnRR] #1119932
11/23/11 07:40 PM
11/23/11 07:40 PM
fresno ca
fresno ca
Thanks John, I found numbers on the right axle tube. three sets.
has # 10 20 9 b7
10 13 9 b2
603080 3
Is that them?
Re: 68 - 70 B BODY DANA DIFFERENCES [Re: mikeysmopars] #1119933
11/23/11 09:13 PM
11/23/11 09:13 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
10 20 9 = Assy date Oct 20, 1969, correct for a 70 vehicle.
Re: 68 - 70 B BODY DANA DIFFERENCES [Re: rayztoy] #1119934
11/23/11 10:34 PM
11/23/11 10:34 PM
Massachusetts
LYNCHROAD69.5 Offline
Massachusetts
603080-3 is the Bill of Material numbers...application is 1969-1971 E-Body with 4:10 gears and Powr-lok...date code (after August of 1969) makes it appropriate for 1970 car...looks like your in business here's a thread with more info https://board.moparts.org/ubbthreads/show...amp;Search=true
Re: 68 - 70 B BODY DANA DIFFERENCES [Re: LYNCHROAD69.5] #1119935
11/23/11 10:42 PM
11/23/11 10:42 PM
fresno ca
fresno ca
Thanks for the info Very Helpful. It is a 4:10 geared Dana and measures 61 5/8" flange to flange. Problem is I need it for a 70 GTX and not right for b body So back to square 1.
Re: 68 - 70 B BODY DANA DIFFERENCES [Re: mikeysmopars] #1119936
11/24/11 02:37 PM
11/24/11 02:37 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
I could give you exactly what you need if you were not on the left coast !
Re: 68 - 70 B BODY DANA DIFFERENCES [Re: 62maxwgn] #1119937
11/24/11 04:26 PM
11/24/11 04:26 PM
fresno ca
fresno ca
what u got? I ship from work every day. mikeysmopars@yahoo.com
Looks like i'm going to have to sell the e body one anyway.
Re: 68 - 70 B BODY DANA DIFFERENCES [Re: mikeysmopars] #1119938
11/25/11 08:48 PM
11/25/11 08:48 PM
MT/AZ
TurbineBronze Offline
MT/AZ
Can someone post a pic of the drain plug on the '68 Dana?
Re: 68 - 70 B BODY DANA DIFFERENCES [Re: TurbineBronze] #1119939
11/26/11 02:10 AM
11/26/11 02:10 AM
I don't have a picture but it's a recessed drive plug in the bottom ofthe housing , the recess accepts a 1/2" square drive.
Re: 68 - 70 B BODY DANA DIFFERENCES [Re: JohnRR] #1119940
11/26/11 10:53 AM
11/26/11 10:53 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
John, have you actually verified by the BOM that a '68 housing has a drain plug? I went through this years ago and came away with the thought that only the '66-'67 units were unique by having a drain plug and being a bit narrower than the other B-body Dana's.
Re: 68 - 70 B BODY DANA DIFFERENCES [Re: 6PakBee] #1119941
11/26/11 01:51 PM
11/26/11 01:51 PM
North Carolina, USA
Silverbullet2 Offline
North Carolina, USA
My 68 GTX has the drain plug.
Re: 68 - 70 B BODY DANA DIFFERENCES [Re: mikeysmopars] #1119942
11/26/11 05:58 PM
11/26/11 05:58 PM
At a gas station near you
badblack68 Offline
badblack68  Offline
All 3 of my 1967 B body Dana 60`s have the drain plug on them. The two 1968 dana 60`s I had did not have the drain plug on them.
Nobody gets in to see the wizard!
Ain`t no way!
Ain`t no how!
Re: 68 - 70 B BODY DANA DIFFERENCES [Re: badblack68] #1119943
11/26/11 06:31 PM
11/26/11 06:31 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
68-69 are 23 spline axles
70 is 35 spline axles
Re: 68 - 70 B BODY DANA DIFFERENCES [Re: 6PakBee] #1119944
11/26/11 06:37 PM
11/26/11 06:37 PM
I was actually at the car that has this rear today but didn't look at it , I'll have it checked but I am pretty sure it is a 68 axle .
Re: 68 - 70 B BODY DANA DIFFERENCES [Re: 6PakBee] #1119945
11/26/11 07:02 PM
11/26/11 07:02 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Every '68 MODEL YEAR Dana 60 I'm familiar with has the drain plug.
