68 - 70 B BODY DANA DIFFERENCES
#1119930
11/23/11 06:28 PM
11/23/11 06:28 PM
Posts: 1,608 fresno ca
mikeysmopars
fresno ca
I need help Identifying the differences in 68 to 70 b body dana 60. What are the obvious differences? breaks, Emergency Break Cable, Part Number locations. I have a 70 gtx I need one for and have severl friends that I can get one from but want to make sure of application. Any pictures and help is appreciated. Thanks in advance!
Founder and CEO of the Central Valley Mopar Drag Pack
Re: 68 - 70 B BODY DANA DIFFERENCES
[Re: mikeysmopars]
#1119931
11/23/11 07:24 PM
11/23/11 07:24 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
If it has BREAKS you want to find one that is not broken.
That aside , the part number is stamped on the right side avle tube towards the center , the brake backing plates are the same , the drums may be different 68/69 vs. 70 , the E brake cables are the same , 68 will have a drain plug in the bottom of the housing.
[Re: JohnRR]
#1119932
11/23/11 07:40 PM
11/23/11 07:40 PM
mikeysmopars
fresno ca
Thanks John, I found numbers on the right axle tube. three sets. has # 10 20 9 b7 10 13 9 b2 603080 3 Is that them?
[Re: mikeysmopars]
#1119936
11/24/11 02:37 PM
11/24/11 02:37 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Thanks for the info Very Helpful. It is a 4:10 geared Dana and measures 61 5/8" flange to flange. Problem is I need it for a 70 GTX and not right for b body So back to square 1.
I could give you exactly what you need if you were not on the left coast !
[Re: 62maxwgn]
#1119937
11/24/11 04:26 PM
11/24/11 04:26 PM
mikeysmopars
fresno ca
what u got? I ship from work every day. mikeysmopars@yahoo.comLooks like i'm going to have to sell the e body one anyway.
[Re: JohnRR]
#1119940
11/26/11 10:53 AM
11/26/11 10:53 AM
Posts: 10,756 North Dakota
6PakBee
North Dakota
John, have you actually verified by the BOM that a '68 housing has a drain plug? I went through this years ago and came away with the thought that only the '66-'67 units were unique by having a drain plug and being a bit narrower than the other B-body Dana's.
[Re: mikeysmopars]
#1119942
11/26/11 05:58 PM
11/26/11 05:58 PM
Posts: 5,044 At a gas station near you
badblack68
All 3 of my 1967 B body Dana 60`s have the drain plug on them. The two 1968 dana 60`s I had did not have the drain plug on them.
Nobody gets in to see the wizard! Ain`t no way! Ain`t no how!
[Re: 6PakBee]
#1119944
11/26/11 06:37 PM
11/26/11 06:37 PM
JohnRR
I was actually at the car that has this rear today but didn't look at it , I'll have it checked but I am pretty sure it is a 68 axle .
