K-FRAME PAINT??? #1119199
11/22/11 03:06 PM
11/22/11 03:06 PM
Clinton Twp... north of Deetro...
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Since my original post disappeared...I'll try again! My k-frame is being removed for a frame rail repair,and was wanting to know what to use that's DURABLE....and ECONOMICAL! If there's a spray-can product out there,that would be GREAT! I hear Rustoleum makes some good epoxy-based paints,but wanted to get some ideas from you guys who have gone this route! Thanks in advance for your thoughts! Randy B.
Re: K-FRAME PAINT??? [Re: Labratt] #1119200
11/22/11 03:37 PM
11/22/11 03:37 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Chassis black from Eastwood has proven to be a very durable paint out of a spray can for me.
Re: K-FRAME PAINT??? [Re: Challenger 1] #1119201
11/22/11 03:42 PM
11/22/11 03:42 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks,Gary! Is it a Satin black..or gloss? BTW...it was great,talking to you,and your wife..at the Donut Cutter,2 Cruises ago! You've got a VERY NICE Challenger!...looks like 2 VERY NICE Challengers,in your sig pic! Randy B.
Re: K-FRAME PAINT??? [Re: Labratt] #1119202
11/22/11 03:54 PM
11/22/11 03:54 PM
Cincinnati, Ohio
Cincinnati, Ohio
Thanks, it's a semi gloss I guess.
Re: K-FRAME PAINT??? [Re: Challenger 1] #1119203
11/22/11 04:01 PM
11/22/11 04:01 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yes semigloss , holds up well and you can get decent results out of the can.
NAPA also sells a chassis black paint I had good results with.
Re: K-FRAME PAINT??? [Re: Labratt] #1119204
11/22/11 04:02 PM
11/22/11 04:02 PM
the house on the left.
cogen80 Offline
cogen80  Offline
i would powder coat it.
Re: K-FRAME PAINT??? [Re: cogen80] #1119205
11/22/11 05:59 PM
11/22/11 05:59 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
if 100% OE correctnes is not a concern this the way I would go.
Re: K-FRAME PAINT??? [Re: gtx6970] #1119206
11/22/11 06:17 PM
11/22/11 06:17 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
if 100% OE correctness is not a concern this the way I would go.
The OP is asking about spray cans so I doubt 100% OE is on his mind.
Powder coat in 45% black and call it a day.
Re: K-FRAME PAINT??? [Re: RJS] #1119207
11/22/11 08:40 PM
11/22/11 08:40 PM
IN
ahy Offline
ahy  Offline
IN
I too have had good results with the Eastwood SG chassis black. If there is some rust on the frame, a first coat of Eastwood black rust encapsulator primer would help it last longer.
If you want to keep cost way down and have access to a small sprayer, hit it with SG black Rustoleum from the hardware store thinned with 10-15% paint thinner... or just brush it on. SG black is very forgiving.
Re: K-FRAME PAINT??? [Re: Challenger 1] #1119208
11/22/11 10:10 PM
11/22/11 10:10 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Who's sway bar kit is that? Tim
Re: K-FRAME PAINT??? [Re: Challenger 1] #1119209
11/22/11 10:18 PM
11/22/11 10:18 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I've used thier Extreme chassis black a bunch of times now and am very happy with it.
Re: K-FRAME PAINT??? [Re: OzHemi] #1119210
11/22/11 10:32 PM
11/22/11 10:32 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
As stated..OE,and factory correct is NOT a concern of mine!...not with all my modifications! In fact,I'm leaning toward painting the engine block BLACK! Orange 8 qt. oil pan..aluminum heads,and orange M-1 intake manifold. I will call my powder-coater for a price! Hopefully,it's reasonable..or I'll have to spray it myself! Thanks,guys!
Re: K-FRAME PAINT??? [Re: OzHemi] #1119211
11/22/11 10:34 PM
11/22/11 10:34 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I used the Krylon Epoxy paint on the 8 3/4 that I put in my 81 shorty 10 years ago.. came out real nice and still looks good today...
I am truckless..
Re: K-FRAME PAINT??? [Re: Labratt] #1119212
11/22/11 10:36 PM
11/22/11 10:36 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Oh, and nice thing about the chassis paint, if you ever do scratch it (not easy to do!) or what not...you can always touch it up...
Re: K-FRAME PAINT??? [Re: Labratt] #1119213
11/22/11 11:08 PM
11/22/11 11:08 PM
Cruising!
Q
QuickDodge Offline
QuickDodge  Offline
Q
Cruising!
Alkyld enamels, such as Rustoluem, two biggest faults are chalking due to UV light exposure (from the sun, etc.) and chemical resistance. Adding some hardener will increase the chemical resistance considerably. Parts underneath the car receive minimal UV light exposure, so Rustoleum with some hardener added should hold up well. This type of finish would be acceptable for a summer time week-end car.
Obviously, a person could spend more money and use an epoxy primer and urethane paint or power coat chassis parts. These are superior coatings. I would seriously consider these finishes for vehicles driven on salt treated roads.
On a vehicle which is driven, any chassis paint or coating will be chipped and scratched over time. So a finish which can be easily repaired is usually a good idea for a frequently driven vehicle.
Re: K-FRAME PAINT??? [Re: QuickDodge] #1119214
11/22/11 11:12 PM
11/22/11 11:12 PM
Dearborn Hts, MI
Sledge_57 Offline
Sledge_57  Offline
Dearborn Hts, MI
Powder Coat maybe? I know a guy if you're interested Randy.
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker
Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
Re: K-FRAME PAINT??? [Re: Sledge_57] #1119215
11/22/11 11:50 PM
11/22/11 11:50 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
Rustoleum in a one pint can, flows well and covers well, the brush marks flow right out. POR also works well and is tough. Neither are sprays, but are more durable. Did the steering boxes make it up OK? Lee.
Re: K-FRAME PAINT??? [Re: Lee446] #1119216
11/23/11 12:07 AM
11/23/11 12:07 AM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
I used a semi gloss black powdercoat, turned out great and will wear well. My powdercoater is way reasonable. Blasting and coating was about $40
Re: K-FRAME PAINT??? [Re: AAR#2] #1119217
11/23/11 12:54 AM
11/23/11 12:54 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Lew..FORTY DOLLARS??? What a deal! Hopfully,Bill at QC Coatings can give me a similiar price! Powder Coating seems like the way to go...if the price is NICE! Thank You ALL for your opinions..and experiences! I truly appreciate it! Randy B.
Re: K-FRAME PAINT??? [Re: AAR#2] #1119218
11/23/11 01:46 AM
11/23/11 01:46 AM
Race City USA Mooresville N.C...
Ts road runner Offline
mopar addict
mopar addict
Powder Coating is the only way to go.
SOUTHERN BORN-SOUTHERN BREED-SOUTHERN DEAD
