Critique this launch. #1117688
11/20/11 01:06 PM
11/20/11 01:06 PM
NY
F1Scamp Offline OP
F1Scamp  Offline OP
NY
This is the only close up launch video I have of the car. It is definitely spinning on this launch, but looks to pick a tire up also. Any ideas on how to improve it?
http://www.youtube.com/watch?v=TYqkjexoIrM&feature=player_profilepage
Work In Progress- 71' Duster F.A.S.T.- 10.36@130 Smallblock Record Holder.
Re: Critique this launch. [Re: F1Scamp] #1117689
11/20/11 01:56 PM
11/20/11 01:56 PM
Antioch, CA
lucky13 Offline
lucky13  Offline
Antioch, CA
Is the car leaning towards the passenger side? Maybe its just the camera angle (or my fat head)
www.racemagnum.com
1954 Plymouth Savoy 2 door
Re: Critique this launch. [Re: lucky13] #1117690
11/20/11 02:55 PM
11/20/11 02:55 PM
NY
F1Scamp Offline OP
F1Scamp  Offline OP
NY
It sits alittle lower on the passengerside. Thats where most of the weight is put.
Re: Critique this launch. [Re: F1Scamp] #1117691
11/20/11 03:44 PM
11/20/11 03:44 PM
Cab_Burge Online work
Cab_Burge  Online Work
It sounded like it may need a little more accelerator pump shot for a little longer
Re: Critique this launch. [Re: Cab_Burge] #1117692
11/21/11 10:00 AM
11/21/11 10:00 AM
NY
F1Scamp Offline OP
F1Scamp  Offline OP
NY
What makes you say that? I think I have it set up for a more heavy, short burst.
Looking at all the videos we have of the car, to me the front end comes up, then down and it unloads the tires. Hard to tell. This is the only video I have of behind the car. I want to be able to leave higher than 1100rpm. I know the first step is a call to Lenny.
Re: Critique this launch. [Re: F1Scamp] #1117693
11/21/11 05:43 PM
11/21/11 05:43 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
looser rebound settings on the rear shock..
id suggest trying to get more rear axle to body separation... either shock or shackle spring movement...
cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
