1970 duster, w5 418, 4 spd e85 #1116423
11/18/11 11:00 PM
11/18/11 11:00 PM
Post falls, Idaho
rgreule Offline OP
rgreule  Offline OP
Post falls, Idaho
well i aquired this car about 4 years ago when i was 19 from a friend of my dads. he gave me the car for helping him change out the rusty body on his 71 f250.. we had to go pick it up was about a 7 hour drive from coeur d alene idaho to mcminville orgon to get it but well worth it when we got there it was sitting up behind a barn where is sat for the previous 10 years. blackberry bushes had grown up to the wind shield and the rear was on blocks.
now 4 years later i finally get a place to work on it. a friend and i got a little shop that we share. he has a 67 mustang
15x10 centerline wheels, gonna need mini tub, and narrowed rear, leaf spring relocation kit and subframe connectors are bought and ready to install.
got the old engine and trans out.
got a 9 inch housing from a friend, along with a big bearing nodular 3rd member with a strange 35 spline spool. getting lightened 4.11 gears for it
found a 73 dart at the local junk yard with front disc brakes fo i picked up all the disc brake stuff for 50 dollars
adapted 4 piston calipers to the factory spindles with this bracket
4 speed stuff..
325/50/15 nitto radials
w5 heads im picking up from a friend.. going to get them shipped off to ryan and shaddy dell for some stage 4 max port work..
a1000 pump
how the shell sits now.. going to get the floor replaced since it had a rubber floor mat in it and rusted the floor out.. thats the only rust though.. also getting a mini tub while the floor is being done.
more to come
Re: 1970 duster, w5 418, 4 spd e85 [Re: rgreule] #1116424
11/19/11 12:23 AM
11/19/11 12:23 AM
Myrtle Beach, SC formerly the ...
340wedge Offline
340wedge  Offline
Looks really solid! Nice project
1971 Sassy Grass Green Duster 340
2006 Charger Daytona GoMango
Re: 1970 duster, w5 418, 4 spd e85 [Re: 340wedge] #1116425
11/19/11 01:38 AM
11/19/11 01:38 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Cool project Looks like you might have some older bodywork lurking in the drivers quarter? What are your plans for paint and body? I know a paint and body good shop who's reasonable in Western WA if you need help.
Re: 1970 duster, w5 418, 4 spd e85 [Re: ScottSmith_Harms] #1116426
11/19/11 01:52 PM
11/19/11 01:52 PM
Post falls, Idaho
rgreule Offline OP
rgreule  Offline OP
Post falls, Idaho
Hey Scott, it's Ryan who sold you the bench seat.. As far as body work and paint I'm taking it to my old work in post falls. Northwest paint and body.. The car is going to get blasted in december so we will see how bad that quarter is.. S
Re: 1970 duster, w5 418, 4 spd e85 [Re: rgreule] #1116427
11/19/11 02:20 PM
11/19/11 02:20 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Small world eh?
Re: 1970 duster, w5 418, 4 spd e85 [Re: ScottSmith_Harms] #1116428
11/19/11 02:28 PM
11/19/11 02:28 PM
Post falls, Idaho
rgreule Offline OP
rgreule  Offline OP
Post falls, Idaho
Yeah no kidding.. Lol. If you ever need a hand working on anything let me know. I'm just up the street..
Re: 1970 duster, w5 418, 4 spd e85 [Re: rgreule] #1116429
11/19/11 04:37 PM
11/19/11 04:37 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
Very cool project! Keep the updates coming
Re: 1970 duster, w5 418, 4 spd e85 [Re: NV69B7RR] #1116430
12/13/11 12:33 AM
12/13/11 12:33 AM
Post falls, Idaho
rgreule Offline OP
rgreule  Offline OP
Post falls, Idaho
little update..
since i will be putting in a fuel cell i cut the tire sump out..
all the glass is out.. almost ready for blasting.
got the rotted out floor out..
used floor i picked up..
car is going to be completly blasted.. underneath and all of the inside so it will be nice to work with clean bare metal every where..
after blasting is mini tub, chromoly cage, and fuel cell mounting and ttrunk sheet metal before it goes to get every square inch painted..
Re: 1970 duster, w5 418, 4 spd e85 [Re: rgreule] #1116431
01/20/12 02:29 PM
01/20/12 02:29 PM
Post falls, Idaho
rgreule Offline OP
rgreule  Offline OP
Post falls, Idaho
update:
blasted and starting of the minitub
[IMG]http://i298.photobucket.com/albums/mm252/rgreule/20b92afe.jpg
[/IMG]
update [Re: rgreule] #1116432
08/08/12 06:48 PM
08/08/12 06:48 PM
Post falls, Idaho
rgreule Offline OP
rgreule  Offline OP
Post falls, Idaho
update.. decided to change it up quite a but and go with a turbo setup..
where im at so far with building the turbo stuff..
borg warner s475
building collectors
9 inch getting a back brace
engine set in for mock up
one manifold mocked up
slowly but surley
Re: update [Re: rgreule] #1116433
08/08/12 07:02 PM
08/08/12 07:02 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
LITTLE update? That's a lot of work son! Good job!
Re: update [Re: ScottSmith_Harms] #1116434
08/08/12 08:16 PM
08/08/12 08:16 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
DAMN....ok I'm definately hooked. I love Dusters, fat tires and anyone who can fab their own turbo stuff that well gets mad respect.......
Will you go for stock paint and stripes? I love the stock look with steam roller tires
Nice man... nice
Re: update [Re: UCUDANT] #1116435
08/08/12 10:30 PM
08/08/12 10:30 PM
Post falls, Idaho
rgreule Offline OP
rgreule  Offline OP
Post falls, Idaho
it will be b5 blue, with factory 340 stripes down the side and tail panel.. sit down pretty low wuth the 325s stuffed in there nice and tight.. hoping it turns out the way i have it in my head..
scott you should come check it out one of these days..
Re: update [Re: rgreule] #1116436
08/08/12 10:48 PM
08/08/12 10:48 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
That sounds like it will be sweet. Wheel well trim to go with the bright wheels?
Re: update [Re: UCUDANT] #1116437
08/09/12 09:32 PM
08/09/12 09:32 PM
Post falls, Idaho
rgreule Offline OP
rgreule  Offline OP
Post falls, Idaho
It will be getting tubbed to the frame rails.. rear suspension is calvert -1 split monos with caltracs.. mived to the frame rail.. car will have every peice of interior and a 10 point cage.. im really hoping to get a alterK front suspension before the car hits the road but we will see.. will be making the passenger side turbo manifold this week
By the way.. this site has the best little face dudes..
Re: update [Re: rgreule] #1116438
08/09/12 10:01 PM
08/09/12 10:01 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Hey Ryan, look what I just bought, a slant 6, 3 speed manual trans, and an A/M radio rounds out the list of original options. (yours will definately be faster)
Re: update [Re: ScottSmith_Harms] #1116439
08/09/12 11:39 PM
08/09/12 11:39 PM
Post falls, Idaho
rgreule Offline OP
rgreule  Offline OP
Post falls, Idaho
Ha.. thats sweet where did you get it? that doesnt look to bad either... oh hey tou wouldnt happen to want a lakewood bell for small block would ya? I was gonna do a 4 speed with the N/a setup i was gonna do.. but figured a 727 would be best with boost.. i bought it for 189 after shipping not looking to make any..
Re: update [Re: rgreule] #1116440
08/10/12 12:16 AM
08/10/12 12:16 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Gimme a call Ryan 922-9115
Re: update [Re: rgreule] #1116441
08/10/12 02:30 AM
08/10/12 02:30 AM
Sask, Can.
72demon416 Offline
72demon416  Offline
Sask, Can.
Looks like a really cool build
Re: update [Re: 72demon416] #1116442
08/16/12 10:56 AM
08/16/12 10:56 AM
Post falls, Idaho
rgreule Offline OP
rgreule  Offline OP
Post falls, Idaho
made more process on the build.. the passenger side turbo manifold is tacked and ready to be finish welded.. now its just the down pipe and y pipe then the turbo fab is finished..
