enough fuel for nos?
#1116405
11/18/11 09:56 PM
11/18/11 09:56 PM
Posts: 251 Saskatchewan (SK)
79410aspenrt
Saskatchewan (SK)
i have asked numerous people this question with answers all over the place.
i have a mallory comp 250 fuel pump. i want to run a 150 hp shot of nos.
will my 250 pump be able to handle this?
550 hp small block.
Re: enough fuel for nos?
[Re: Wicked49670dart]
#1116412
11/20/11 12:21 AM
11/20/11 12:21 AM
79410aspenrt
Saskatchewan (SK)
thanks guys for the comments. i run -8 line from tank to filter then to pump. from pump to regulator, -8 also. then -6 from regulator which feeds both carbs. how much et will i pick up from a 150 shot? best et now is a 11.54 @ 118.56 mph.
[Re: 79410aspenrt]
#1116414
11/20/11 10:32 PM
11/20/11 10:32 PM
Posts: 10,766 Central Valley, CA.
Quicksilver440
Central Valley, CA.
you'll probably cut a second off your times...
[Re: Cab_Burge]
#1116416
11/21/11 03:17 AM
11/21/11 03:17 AM
Posts: 1,397 Carson City, Nevada
Biginchmopar
Carson City, Nevada
Cab, With all the testing I have done with nitrous, I never found the need to go any bigger, ever! That pump will feed a 750-800hp motor and a 500hp nitrous hit. Those pumps move a ton of fuel. I always use a return style regulator.
