Re: 1970 CUDA Tail light wiring harness - couple questions. [Re: 70plymA34] #1116197
11/22/11 05:29 PM
11/22/11 05:29 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
same here, the car is done and all the lights work perfectly. I went thru the boxes with the old/original wiring that came with this car, and no signs of this single ground wire.
Sadly , I got the car in boxes, so I can't say if this car ever had one or not.
And I had lunch with the cars owner today and he couldn't remember one way or the other
Re: 1970 CUDA Tail light wiring harness - couple questions. [Re: gtx6970] #1116198
11/23/11 11:31 PM
11/23/11 11:31 PM
MrNormTA Offline
MrNormTA  Offline
I just removed my taillights from my 70 gran coupe and it has the same exact ground wire. My lights have never been removed and the car is a 9/69 build date. Although my mounting nuts for the lights look just like the acorn style nuts holding the small side marker light in on the above photo. The photo Bill linked for the retaining nuts looks more correct for a challenger.
Re: 1970 CUDA Tail light wiring harness - couple questions. [Re: MrNormTA] #1116199
11/24/11 12:31 AM
11/24/11 12:31 AM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
I have also owned a couple of '70 'Cudas with that acorn style as well.
Re: 1970 CUDA Tail light wiring harness - couple questions. [Re: 70440+6bbl] #1116200
11/24/11 10:08 PM
11/24/11 10:08 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
I wonder when the change-over occured...My 70 {SPD 9/11/69} had the acorn style...The above engineering drawing shows them being used...
Re: 1970 CUDA Tail light wiring harness - couple questions. [Re: screamindriver] #1116201
11/25/11 01:15 PM
11/25/11 01:15 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Although I've not looked in the trunk of every Cuda out there, but this is the 1st I've seen or heard of this kind of palnut used on an E-body.
I've seen something similar used on various B-bodies though( different sizes)
70-71 Challengers are 10-24 machine thread
But these ? maybe production date or plant thing ?
8-32 machine thread - same nut as used on the sidemarker lamps.
