Re: radio help for electrically deficient
[Re: BTTG]
#1115477
11/17/11 11:49 AM
11/17/11 11:49 AM
RapidRobert
W the battery and radio on your bench and some jumper wires, positive to 12V input and make sure you not on the dash light but the actual power in, ground chassis to neg. 2 wires to speaker. I think there is a little "trimmer" knob somewhere on the case to fine tune the reception but it sounds like your dead in the water. Not sure if there is an internal fuse or not. Not much info but that'd be where I'd start and almost forgot if you get any noise you'd want to plug in the antennae and jumper it to the case also
[Re: BTTG]
#1115480
11/18/11 11:30 AM
11/18/11 11:30 AM
Posts: 1,822 Colorado
denfireguy
Colorado
All the of the above is good advice. If you do not have an antenna attached, you may not hear anything still. Take the covers off the radio and hook it up. On the antenna connector on the inside, put your finger on a screwdriver blade and touch the antenna input, not the ground. You should hear signals from strong stations with your body acting as the antenna (yes, you can do this at home even as an untrained non professional). If you do hear stuff, the radio is working. If you don't next step is to find the volume control. Using the same technique, put the screwdriver on the middle lug of the volume control. You should hear hum in the radio speaker variable with the volume control. If there is not, the audio section of the radio is bad, probably the output transistor. That is the most probable failure of a solid state car radio. With tube type radios, don't do any of this because you could get knocked on your can. One other tip, the volume control is usually concentric with the tone control. The volume control is the rear gang of the two controls. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: RapidRobert]
#1115482
11/19/11 12:23 AM
11/19/11 12:23 AM
denfireguy
Colorado
Maybe rephrase it: Not enough noise will be present to detect in the speaker, especially with these old ears.
[Re: denfireguy]
#1115483
11/19/11 01:37 AM
11/19/11 01:37 AM
Posts: 4,247 Alabama
BigMoneyLewis
Alabama
Generally , with an AM , with no antenna plugged in you will hear nothing at all, and with an AM FM, only the strongest stations will be audible with no antenna . You mention only having a single rear speaker in the car . All '69 B bodies with R11 came with the single 4x10 dash speaker. A single rear was an option , and would pass through a factory rear fader switch. If you can't get it going , that's what we do all day ,every day , so send me an e-mail.
Greg
