rear shock upgrade
#1114964
11/16/11 09:40 AM
11/16/11 09:40 AM
Posts: 3,210 robin hood country
deaks
robin hood country
I currently run rancho 9 ways on the rear of my ride and even on the stiffest setting i'm getting a fair amount of separation, car has SS springs clamped on the front sections. Anyway, it got me to thinking, what single adjustable shocks are available that might offer a stiffer ride, without remortgaging the house to pay for them. Any ideas. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
Re: rear shock upgrade
[Re: one bad fish]
#1114966
11/16/11 03:47 PM
11/16/11 03:47 PM
deaks
robin hood country
Is there anything in between afco and what i've got price wise. Just googled the single adjustables and they are $210 each. Mick
[Re: deaks]
#1114967
11/16/11 05:15 PM
11/16/11 05:15 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
Mick, I use the single adjustabe QA-1's on mine Seem to work well for me They are rebuildable they may be able to revalve to suite your needs if you need more control
[Re: joshking440]
#1114970
11/16/11 06:52 PM
11/16/11 06:52 PM
deaks
robin hood country
Twin turbo mower Please elaborate Quote:
with super stock springs, how can you begin to control that seperation?
I thought that was the whole idea behind that spring...
What would you suggest ?, bear in mind, this is at most a 600 hp car. Mick
[Re: mopar_mark]
#1114972
11/16/11 08:19 PM
11/16/11 08:19 PM
Posts: 2,933 A shed in England
Tig
A shed in England
Mick, aren't you on caltracs? Does the car 60ft best on the stiffest extension settings?
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: joshking440]
#1114974
11/17/11 12:55 PM
11/17/11 12:55 PM
deaks
robin hood country
Mark Thank you i really appreciate that. Tig No caltracs here, best 60ft on a decent track, 1.44 shocks on 9 Josh Thanks for the tip. Pricewise, there's not much difference qa1's to Afco single adjustables. To be fair, a bit more converter stall might help the 60ft's at present 4800.
[Re: deaks]
#1114975
11/17/11 01:33 PM
11/17/11 01:33 PM
Posts: 4,752 Moved to N.E. Tennessee
GomangoCuda
Which SS springs do you have? At 600HP I would hope you have 002/003 springs. Any of the others are really too soft for that much power and will seperate a bunch. Just my opinion, others will undoubtedly disagree.
Personally I would put Caltracs and monoleafs on it and never look back.
[Re: deaks]
#1114976
11/17/11 01:44 PM
11/17/11 01:44 PM
Posts: 912 London, England
mopar_mark
London, England
No problem. PM me, when you decide what you want to do, then we can discuss how, where to send, etc
[Re: mopar_mark]
#1114977
11/17/11 02:27 PM
11/17/11 02:27 PM
deaks
robin hood country
Cheers Mark Gomango cuda Yes they are 002 003 springs and not the mexican ones. Mick
[Re: Twin Turbo Mower]
#1114979
11/17/11 05:41 PM
11/17/11 05:41 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Afco double adj. works great. Got rid of the ranchos.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 1967dartgt]
#1114980
11/17/11 08:46 PM
11/17/11 08:46 PM
deaks
robin hood country
What sort of results have you had before and after and what shocks were on before the afco's ? Mick
#1114982
11/18/11 02:57 PM
11/18/11 02:57 PM
Tig
A shed in England
When you use the rancho's every adjustment affects the extension and compression. So for the stiff setting on compression it is also stiff on the extension not allowing the car to lift in the back as easy and put weight on the back tires.
Sorry to Hijack, That is something I didn't know, I thought Compression damping (jounce) was fixed on the Rancho's. Goes someway to explaining why my car does what it does.
[Re: Tig]
#1114983
11/18/11 08:09 PM
11/18/11 08:09 PM
Posts: 1,056 Mt.Vernon IL
Twin Turbo Mower
Mt.Vernon IL
It might have been. Its been about 4 years since I have had the rancho's. When I had them off the car I would mess with the settings and extend and compress the shock to see how they acted for each setting.
