rear shock upgrade #1114964
11/16/11 09:40 AM
11/16/11 09:40 AM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
I currently run rancho 9 ways on the rear of my ride and even on the stiffest setting i'm getting a fair amount of separation, car has SS springs clamped on the front sections.
Anyway, it got me to thinking, what single adjustable shocks are available that might offer a stiffer ride, without remortgaging the house to pay for them.
Any ideas.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: rear shock upgrade [Re: deaks] #1114965
11/16/11 11:22 AM
11/16/11 11:22 AM
bronx n.y
O
one bad fish Offline
O
bronx n.y
Afco double adjustable work great
Re: rear shock upgrade [Re: one bad fish] #1114966
11/16/11 03:47 PM
11/16/11 03:47 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
Is there anything in between afco and what i've got price wise. Just googled the single adjustables and they are $210 each.
Mick
best 60ft 1.36
Re: rear shock upgrade [Re: deaks] #1114967
11/16/11 05:15 PM
11/16/11 05:15 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Mick, I use the single adjustabe QA-1's on mine
Seem to work well for me
They are rebuildable they may be able to revalve to suite your needs if you need more control
Re: rear shock upgrade [Re: roadhazard] #1114968
11/16/11 05:42 PM
11/16/11 05:42 PM
Mt.Vernon IL
Twin Turbo Mower Offline
Mt.Vernon IL
I also use afco's. Day and night compared to single adjustabl shocks.
Re: rear shock upgrade [Re: Twin Turbo Mower] #1114969
11/16/11 05:49 PM
11/16/11 05:49 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
with super stock springs, how can you begin to control that seperation?
I thought that was the whole idea behind that spring...
Re: rear shock upgrade [Re: joshking440] #1114970
11/16/11 06:52 PM
11/16/11 06:52 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
Twin turbo mower
Please elaborate
What would you suggest ?, bear in mind, this is at most a 600 hp car.
Mick
best 60ft 1.36
Re: rear shock upgrade [Re: deaks] #1114971
11/16/11 08:12 PM
11/16/11 08:12 PM
London, England
mopar_mark Offline
mopar_mark  Offline
London, England
Mick
Mick,
I can help with shipping, as in, got a guy who works for me, who will be going to the states in Dec. Just need to pay UK postage, so $210 at todays rate is £134 + £10 ? for UK postage or for any shock you decide, any little savings help
You would just need to get them sent to my mates, let me know if your interested
Re: rear shock upgrade [Re: mopar_mark] #1114972
11/16/11 08:19 PM
11/16/11 08:19 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Mick, aren't you on caltracs? Does the car 60ft best on the stiffest extension settings?
Re: rear shock upgrade [Re: Tig] #1114973
11/16/11 11:19 PM
11/16/11 11:19 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
deaks, Im not sure I have the answer, but I had always been under the assumotion that SuperStock Springs work because of the massive seperation... Now if thats not correct, im not sure. If you buy afcos, make sure yu call eric and tell him you want the big dog valving because I had to send mine in once already. I still cant control it, so I am probably putting red shocks on my car
Re: rear shock upgrade [Re: joshking440] #1114974
11/17/11 12:55 PM
11/17/11 12:55 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
Mark
Thank you i really appreciate that.
Tig
No caltracs here, best 60ft on a decent track, 1.44 shocks on 9
Josh
Thanks for the tip.
Pricewise, there's not much difference qa1's to Afco single adjustables.
To be fair, a bit more converter stall might help the 60ft's at present 4800.
best 60ft 1.36
Re: rear shock upgrade [Re: deaks] #1114975
11/17/11 01:33 PM
11/17/11 01:33 PM
Moved to N.E. Tennessee
GomangoCuda Online work
GomangoCuda  Online Work
Which SS springs do you have? At 600HP I would hope you have 002/003 springs. Any of the others are really too soft for that much power and will seperate a bunch. Just my opinion, others will undoubtedly disagree.
Personally I would put Caltracs and monoleafs on it and never look back.
Re: rear shock upgrade [Re: deaks] #1114976
11/17/11 01:44 PM
11/17/11 01:44 PM
London, England
mopar_mark Offline
mopar_mark  Offline
London, England
Mark
No problem.
PM me, when you decide what you want to do, then we can discuss how, where to send, etc
Re: rear shock upgrade [Re: mopar_mark] #1114977
11/17/11 02:27 PM
11/17/11 02:27 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
Cheers Mark
Gomango cuda
Yes they are 002 003 springs and not the mexican ones.
Mick
best 60ft 1.36
Re: rear shock upgrade [Re: deaks] #1114978
11/17/11 05:01 PM
11/17/11 05:01 PM
Mt.Vernon IL
Mt.Vernon IL
When you use the rancho's every adjustment affects the extension and compression. So for the stiff setting on compression it is also stiff on the extension not allowing the car to lift in the back as easy and put weight on the back tires. The lose setting is the same fast sepration but no compression. The afco's you adjust each one seperate. On mine I have them lose as can be on the extension and firm on the compression. I do have the extension 2 setting firm on the drivers side to control roll over so the rear lifts equally. Spend the money on the shocks it is well worth it especially for small tire cars.
Re: rear shock upgrade [Re: Twin Turbo Mower] #1114979
11/17/11 05:41 PM
11/17/11 05:41 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Afco double adj. works great. Got rid of the ranchos.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: rear shock upgrade [Re: 1967dartgt] #1114980
11/17/11 08:46 PM
11/17/11 08:46 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
What sort of results have you had before and after and what shocks were on before the afco's ?
Mick
best 60ft 1.36
Re: rear shock upgrade [Re: deaks] #1114981
11/18/11 01:49 AM
11/18/11 01:49 AM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: rear shock upgrade [Re: Twin Turbo Mower] #1114982
11/18/11 02:57 PM
11/18/11 02:57 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Sorry to Hijack, That is something I didn't know, I thought Compression damping (jounce) was fixed on the Rancho's.
Goes someway to explaining why my car does what it does.
Re: rear shock upgrade [Re: Tig] #1114983
11/18/11 08:09 PM
11/18/11 08:09 PM
Mt.Vernon IL
Mt.Vernon IL
It might have been. Its been about 4 years since I have had the rancho's. When I had them off the car I would mess with the settings and extend and compress the shock to see how they acted for each setting.
