Hy-Lift Johnson Hydro Roller lifter #1113865
11/14/11 09:42 PM
11/14/11 09:42 PM
New Mexico
Adobedude Offline OP
New Mexico
Did a search...No results.
Anyone using these on a Magnum Motor...?
http://www.hughesengines.com/Index/produ...mp;partid=26611
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: Hy-Lift Johnson Hydro Roller lifter [Re: Adobedude] #1113866
11/15/11 04:38 PM
11/15/11 04:38 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Did my research and found this:
http://www.toplineauto.com/
Re: Hy-Lift Johnson Hydro Roller lifter [Re: Biginchmopar] #1113867
11/15/11 07:36 PM
11/15/11 07:36 PM
New Mexico
New Mexico
Thanks...
I'm looking for someone whom has run them, or has seen the insides. My Stock lifters are falling apart, not breaking or collapsing, but the cup that holds the check valve ball is coming off the housing...Seems to be a common problem with the Mopar lifters, it's only a press fit.
I suppose I could order one lifter from Hughes and take it apart.
Or spend 600.00 on the Comp 8043 lifters...Yikes!
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
