Re: Real A body 4" BC axles, anyone make?
[Re: Moonraker]
#111107
08/27/08 12:43 PM
08/27/08 12:43 PM
Posts: 1,195 Snowing in the north!
Dart 340
moparts member
moparts member
I'm sure there is but I cant think of any right off hand, Yukon maybe. Most guys want to get rid of their 4" bolt pattern axles and get 4.5" because there are a lot more wheel choices. I cant even give away the A-body 4" BP axles I replaced years back in the Duster. If you need a replacement check in the parts sections, there are always a ton for sale there.
I would be happy to take them off your hands!
[Re: Dart 340]
#111108
08/27/08 12:44 PM
08/27/08 12:44 PM
Posts: 75,089 A Banana Republic near you.
JohnRR
No actually I have the factory 4 piston disk brakes on the front of the car and the original wheels, so it makes more sense for me to keep her all original.
I have 2 sets of axles but neither are spectacular. Was thinking a nice set would be good to have....
I think I could have Moser make a custom set for me for about 600 dollars.
I don't think its that big a price difference , i want to say that a hi strength axle in both 4" BP , register and brake offset should be readily available , maybe a short lead time to make ?
Keep us posted , I could use a set .
[Re: DoctorDiff]
#111111
08/27/08 01:56 PM
08/27/08 01:56 PM
Dart 340
moparts member
moparts member
I sell new 5 x 4" axles all the time. They run $390 pair, assembled with studs and Green bearings.
I didn't think the aftermarket axles would fit into the stock setup? Something with brakes or housing?
[Re: Dart 340]
#111113
08/27/08 02:01 PM
08/27/08 02:01 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Why wouldn't they. If they are Built to spec's they will fit just as well as OEM.
[Re: Dart 340]
#111116
08/27/08 04:00 PM
08/27/08 04:00 PM
JohnRR
my understanding was they are not built to spec.
a large bolt pattern is not built to a body specs , the offset of the axle flange is different to accommodate the larger body brake setups , but it makes zero sense for any company to make a small bolt pattern axle that will not fit a body offset spec , the only SILLY thing i can think of is the axles being too short because of the green bearings CAUSING an issue.
