Page 3 of 3 1 2 3
Re: NEW BEST 9.85 137 mph [Re: moparniac] #1111027
11/17/11 07:18 PM
11/17/11 07:18 PM
long island NY
Ari440 Offline OP
Ari440  Offline OP
long island NY
and some bigger headers migth need to go 2 1/4 to 4 inch collecters
naaaaaaaaa
on your proparts headers that are 2 -2 1/4 what size is the collecters?
im thinking that I could get some more power out of it than what it is now
any thougths on this
1.39 9.85 - 137 mph
Re: NEW BEST 9.85 137 mph [Re: Ari440] #1111028
11/17/11 08:29 PM
11/17/11 08:29 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Dont TTI make a 2"-2-1/8 step header, or stahl headers are 2-1/8 as well.
BTW Congrats on your time
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: NEW BEST 9.85 137 mph [Re: Ari440] #1111029
11/17/11 08:46 PM
11/17/11 08:46 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
naaaaaaaaa
Yes I have the new proparts/ TTI deal that are 2 to 2 1/8 th steps and they are 3 1/2" collectors... Only got the car out twice to the track and 1 time was for an event and had to work first and third shift just to go have fun...
Mopar Performance
Re: NEW BEST 9.85 137 mph [Re: moparniac] #1111030
11/17/11 08:51 PM
11/17/11 08:51 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
People always seem to say the full
Hooker fenderwells make more power than the proparts... Who knows! I know our combos are similar and run the cnc345s . I saw you posted you went from single 4 to the tunnel ram!
Mopar Performance
Re: NEW BEST 9.85 137 mph [Re: moparniac] #1111031
11/17/11 09:20 PM
11/17/11 09:20 PM
long island NY
Ari440 Offline OP
Ari440  Offline OP
long island NY
I had the cppa /tti headers very tigth fit and the hooker headers no room for tire and master cylinder ,just didmt like them , I even welded back the panels that I cut off
1050 had 98 jets went to a tunnelram two 750s 80 jets in them , timming at *38
the heddman headers look nice to try out or go custem
1.39 9.85 - 137 mph
Re: NEW BEST 9.85 137 mph [Re: Ari440] #1111032
11/17/11 11:10 PM
11/17/11 11:10 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Mopar Performance
Re: NEW BEST 9.85 137 mph [Re: moparniac] #1111033
11/18/11 10:16 AM
11/18/11 10:16 AM
an8sec70cuda Offline
ARI...I have to agree w/ sledgehammer about the timing. I'm assuming you have flattop pistons since your compression is around 12:1 w/ those heads and that many cubes. If so, then you ought to try backing the timing down to 36°, then try 34°. I bet it runs better w/ less timing.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: NEW BEST 9.85 137 mph [Re: an8sec70cuda] #1111034
11/18/11 02:08 PM
11/18/11 02:08 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Chip I'm starting to get this SV1 tuned in better! I went 111 and change in the 1/8th and went from 28 to 32s on the highs and I went 112.8mph on back to back passes and nothing else changed... 60s were even 1.44 each... It was a hair over 1.5mph pickup! I have lots more tuning left but only other time out was the Jensen mean street deal.
Mopar Performance
Re: NEW BEST 9.85 137 mph [Re: moparniac] #1111035
11/18/11 06:20 PM
11/18/11 06:20 PM
long island NY
Ari440 Offline OP
Ari440  Offline OP
long island NY
compresion is 13.1
flat top J/E pistons 7cc valve releafs and 71cc heads
next time out I will have the 1050 with 95 jets and *35 timming
need to stay out of the 9 sec zone or im going home again
I will do some 1/8 mile testing or get my comp lesions (sp)
thanks for the tips !
1.39 9.85 - 137 mph
Re: NEW BEST 9.85 137 mph [Re: Ari440] #1111036
11/18/11 06:45 PM
11/18/11 06:45 PM
Guitar Jones Offline
compresion is 13.1
Just go ahead and get you license and the full monkey suit. It really wasn't that hard. I went to a walk in clinic for the physical, $100. Made all the passes on a test and tune night.
Re: NEW BEST 9.85 137 mph [Re: Guitar Jones] #1111037
11/18/11 07:11 PM
11/18/11 07:11 PM
long island NY
Ari440 Offline OP
Ari440  Offline OP
long island NY
compresion is 13.1
is there a blindfold test to do too
just incase of an accedent (sp)
1.39 9.85 - 137 mph
Re: NEW BEST 9.85 137 mph [Re: Ari440] #1111038
11/18/11 09:24 PM
11/18/11 09:24 PM
bronx n.y
O
one bad fish Offline
O
bronx n.y
good job
Re: NEW BEST 9.85 137 mph [Re: Ari440] #1111039
11/18/11 10:56 PM
11/18/11 10:56 PM
compresion is 13.1
You know your car right. Could you hit the shut off without seeing it? You pass. Just line up a couple people you know that are licensed to sign your application before you do it. No sweat.
Page 3 of 3 1 2 3
