Re: NEW BEST 9.85 137 mph
[Re: Ari440]
#1111028
11/17/11 08:29 PM
11/17/11 08:29 PM
Posts: 3,210 robin hood country
deaks
robin hood country
Dont TTI make a 2"-2-1/8 step header, or stahl headers are 2-1/8 as well. BTW Congrats on your time
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: moparniac]
#1111030
11/17/11 08:51 PM
11/17/11 08:51 PM
Posts: 6,295 U.S.
moparniac
U.S.
People always seem to say the full Hooker fenderwells make more power than the proparts... Who knows! I know our combos are similar and run the cnc345s . I saw you posted you went from single 4 to the tunnel ram!
Mopar Performance
[Re: moparniac]
#1111031
11/17/11 09:20 PM
11/17/11 09:20 PM
Posts: 5,620 long island NY
Ari440
long island NY
I had the cppa /tti headers very tigth fit and the hooker headers no room for tire and master cylinder ,just didmt like them , I even welded back the panels that I cut off
1050 had 98 jets went to a tunnelram two 750s 80 jets in them , timming at *38
the heddman headers look nice to try out or go custem
1.39 9.85 - 137 mph
[Re: moparniac]
#1111033
11/18/11 10:16 AM
11/18/11 10:16 AM
Posts: 13,404 Marion, South Carolina [><]
an8sec70cuda
ARI...I have to agree w/ sledgehammer about the timing. I'm assuming you have flattop pistons since your compression is around 12:1 w/ those heads and that many cubes. If so, then you ought to try backing the timing down to 36°, then try 34°. I bet it runs better w/ less timing.
[Re: an8sec70cuda]
#1111034
11/18/11 02:08 PM
11/18/11 02:08 PM
Posts: 6,295 U.S.
moparniac
U.S.
Chip I'm starting to get this SV1 tuned in better! I went 111 and change in the 1/8th and went from 28 to 32s on the highs and I went 112.8mph on back to back passes and nothing else changed... 60s were even 1.44 each... It was a hair over 1.5mph pickup! I have lots more tuning left but only other time out was the Jensen mean street deal.
Mopar Performance
[Re: moparniac]
#1111035
11/18/11 06:20 PM
11/18/11 06:20 PM
Ari440
long island NY
compresion is 13.1 flat top J/E pistons 7cc valve releafs and 71cc heads next time out I will have the 1050 with 95 jets and *35 timming need to stay out of the 9 sec zone or im going home again I will do some 1/8 mile testing or get my comp lesions (sp) thanks for the tips !
1.39 9.85 - 137 mph
[Re: Ari440]
#1111036
11/18/11 06:45 PM
11/18/11 06:45 PM
Posts: 20,678 in a cattle trailer down by th...
Guitar Jones
compresion is 13.1
Just go ahead and get you license and the full monkey suit. It really wasn't that hard. I went to a walk in clinic for the physical, $100. Made all the passes on a test and tune night.
[Re: Ari440]
#1111039
11/18/11 10:56 PM
11/18/11 10:56 PM
Guitar Jones
compresion is 13.1
is there a blindfold test to do too
just incase of an accedent (sp)
You know your car right. Could you hit the shut off without seeing it? You pass. Just line up a couple people you know that are licensed to sign your application before you do it. No sweat.
