Drag racing ONLY....To run a thermostat or not? #1110943
11/10/11 06:24 PM
11/10/11 06:24 PM
Forest Grove,Oregon
beepbeepdon Offline OP
Forest Grove,Oregon
I wanted to get a consensus as to what you all think regarding running a thermostat.Who runs one,who doesnt and who runs one with the center cut out( attemping to "slow" the flow as I was told by someone.Obviously we should always run straight water and maybe Water Wetter but no coolant.....My question is should I run one or not?....Thanks for your time
Re: Drag racing ONLY....To run a thermostat or not? [Re: beepbeepdon] #1110944
11/10/11 06:28 PM
11/10/11 06:28 PM
Guitar Jones Offline
I do not run one but I have the center cut out of one so I can build some heat. Electric water pump and fan, it's the only way to really control the temp. I like to start my burnout at 130, around 140 when I stage.
Re: Drag racing ONLY....To run a thermostat or not? [Re: beepbeepdon] #1110945
11/10/11 06:30 PM
11/10/11 06:30 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
I run one with the center out of it and distill water. But I think this depends on your car and cooling sys. and how you run the car. Do you have elec fan..water pump ? are they tie together and run both at the same time ? I do beleve that you need something in there to help keep it in radiator so it will cool it ?
Re: Drag racing ONLY....To run a thermostat or not? [Re: VernMotor] #1110946
11/10/11 06:33 PM
11/10/11 06:33 PM
With an electric pump you aren't moving the water that fast, I could do with out the restrictor but I don't like leaving the water pump off with the engine running. The fan and pump should be able to work seperately. I run just the pump to get to temp and then turn the fan on. It's on a 3 position rocker switch, off, pump only or fan and pump.
Re: Drag racing ONLY....To run a thermostat or not? [Re: beepbeepdon] #1110947
11/10/11 06:39 PM
11/10/11 06:39 PM
Renton Washington
Triple Threat Offline
Renton Washington
I run nothing at all.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Drag racing ONLY....To run a thermostat or not? [Re: beepbeepdon] #1110948
11/10/11 06:40 PM
11/10/11 06:40 PM
an8sec70cuda Offline
If you have an electric water pump, don't run a thermostat or a restrictor.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Drag racing ONLY....To run a thermostat or not? [Re: beepbeepdon] #1110949
11/10/11 06:46 PM
11/10/11 06:46 PM
Forest Grove,Oregon
Forest Grove,Oregon
Thanks everyone...I run a stock aluminum water pump and electric fan ( summit's with relay on a toggle)....No cooling problems unless I sit and idle too long (Havent let it get higher than 200 yet so not sure if I have the right setup or not....Just got the car at the track this past summer than cam failure set in....Thats a whole different story tho.....Thanks again
Re: Drag racing ONLY....To run a thermostat or not? [Re: an8sec70cuda] #1110950
11/10/11 06:48 PM
11/10/11 06:48 PM
sweden
sshemi Offline
sshemi  Offline
sweden
please explain why not.
Doesnt an electric pump move more water than a mech at idle?
Im about to use both a stat and the heater.
Re: Drag racing ONLY....To run a thermostat or not? [Re: sshemi] #1110951
11/10/11 07:01 PM
11/10/11 07:01 PM
You can leave the pump running and completely cool the motor down. If the thermostat closes, you can't circulate water.
Meziere says NOT to run a thermostat w/ any of their pumps.
CHIP
Re: Drag racing ONLY....To run a thermostat or not? [Re: sshemi] #1110952
11/10/11 10:09 PM
11/10/11 10:09 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
i have a electric pump. mainly street driven. no heater. 180 stat with a 1/8 hole drilled near opening. been running this for years, 170 down the road, 200 sitting in traffic. racing, 180. no problems. stay safe, seeya.
Re: Drag racing ONLY....To run a thermostat or not? [Re: an8sec70cuda] #1110953
11/10/11 10:31 PM
11/10/11 10:31 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
you cant circulate water in and or out of the radiator..but it still circulates through the pump-engineblock-heads and intake..fwiw.
cheapst
If you street drive the car id expect you'll realise you need a thermostat.. but this was stated race only in the heading..
cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: Drag racing ONLY....To run a thermostat or not? [Re: cheapstreetdustr] #1110954
11/10/11 11:36 PM
11/10/11 11:36 PM
Renton Washington
Renton Washington
cheapst
My car gets driven year round, with no thermostat.
-Dustin
Re: Drag racing ONLY....To run a thermostat or not? [Re: beepbeepdon] #1110955
11/11/11 12:49 AM
11/11/11 12:49 AM
Az
Crizila Offline
Crizila  Offline
Az
Race only, forget the stat.
Fastest 300
Re: Drag racing ONLY....To run a thermostat or not? [Re: Crizila] #1110956
11/11/11 12:58 AM
11/11/11 12:58 AM
On the run…
BloFish Online penguin-006
BloFish  Online Penguin-006
On the run…
Street strip, leave it in?
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Drag racing ONLY....To run a thermostat or not? [Re: BloFish] #1110957
11/11/11 03:09 AM
11/11/11 03:09 AM
long island newyork
Abodyjohn88 Offline
Abodyjohn88  Offline
long island newyork
no thermostat in mine either and i drive it year round. takes a few minutes to warkm up but rarley gos above 200 in bumper to bumper traffic
Re: Drag racing ONLY....To run a thermostat or not? [Re: Abodyjohn88] #1110958
11/11/11 09:40 AM
11/11/11 09:40 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
you dont need a thermostat....and you dont need a restrictor. the holes in the heads will restrict the water
Re: Drag racing ONLY....To run a thermostat or not? [Re: beepbeepdon] #1110959
11/11/11 09:59 PM
11/11/11 09:59 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
To me this is not a one answer fits all question, depends on your set-up. Small rad & gas - no stat. Big rad & e85 bracket car makes it easier to keep it at the same starting line temp.
"Just a Bracket car dressed up like a streetcar"
Re: Drag racing ONLY....To run a thermostat or not? [Re: Just-a-dart] #1110960
11/12/11 02:23 AM
11/12/11 02:23 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
The only reason to restrict flow is to make the engine run hotter, or to prevent pump pressure from blowing the cap open on a top tank radiator. You can not make the engine run cooler by restricting flow. That is an old wives tale that has been disproven by scientific testing. Higher flow = lower, more consistant temps in the heads, reduces steam pockets and reduces detonation. Proceed acordingly.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Drag racing ONLY....To run a thermostat or not? [Re: Hemi_Joel] #1110961
11/12/11 06:12 AM
11/12/11 06:12 AM
sweden
sshemi Offline
sshemi  Offline
sweden
Is that really a fact?
I believe that if water flows slow through the rad it will be cooler entering the motor.
Btw i have always used a stat with a mech pump.
I even used a stat on my hemi with elec pump seemed to work but got too little run time to say for sure
Re: Drag racing ONLY....To run a thermostat or not? [Re: sshemi] #1110962
11/12/11 11:59 AM
11/12/11 11:59 AM
Az
Crizila Offline
Crizila  Offline
Az
Yes, it's a fact. The more times you can pass it through the rad, the more heat will be removed from the coolant.
Fastest 300
