Re: Drag racing ONLY....To run a thermostat or not?
[Re: beepbeepdon]
#1110944
11/10/11 06:28 PM
11/10/11 06:28 PM
Posts: 20,677 in a cattle trailer down by th...
Guitar Jones
I do not run one but I have the center cut out of one so I can build some heat. Electric water pump and fan, it's the only way to really control the temp. I like to start my burnout at 130, around 140 when I stage.
[Re: VernMotor]
#1110946
11/10/11 06:33 PM
11/10/11 06:33 PM
Guitar Jones
With an electric pump you aren't moving the water that fast, I could do with out the restrictor but I don't like leaving the water pump off with the engine running. The fan and pump should be able to work seperately. I run just the pump to get to temp and then turn the fan on. It's on a 3 position rocker switch, off, pump only or fan and pump.
[Re: beepbeepdon]
#1110948
11/10/11 06:40 PM
11/10/11 06:40 PM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
If you have an electric water pump, don't run a thermostat or a restrictor. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: an8sec70cuda]
#1110950
11/10/11 06:48 PM
11/10/11 06:48 PM
Posts: 2,128 sweden
sshemi
sweden
please explain why not. Doesnt an electric pump move more water than a mech at idle? Im about to use both a stat and the heater.
[Re: sshemi]
#1110951
11/10/11 07:01 PM
11/10/11 07:01 PM
an8sec70cuda
You can leave the pump running and completely cool the motor down. If the thermostat closes, you can't circulate water. Meziere says NOT to run a thermostat w/ any of their pumps.
[Re: beepbeepdon]
#1110955
11/11/11 12:49 AM
11/11/11 12:49 AM
Posts: 7,506 Az
Crizila
Az
Race only, forget the stat.
Fastest 300
[Re: Crizila]
#1110956
11/11/11 12:58 AM
11/11/11 12:58 AM
Posts: 16,546 On the run…
BloFish
On the run…
Street strip, leave it in?
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: beepbeepdon]
#1110959
11/11/11 09:59 PM
11/11/11 09:59 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
To me this is not a one answer fits all question, depends on your set-up. Small rad & gas - no stat. Big rad & e85 bracket car makes it easier to keep it at the same starting line temp.
"Just a Bracket car dressed up like a streetcar"
[Re: Just-a-dart]
#1110960
11/12/11 02:23 AM
11/12/11 02:23 AM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
The only reason to restrict flow is to make the engine run hotter, or to prevent pump pressure from blowing the cap open on a top tank radiator. You can not make the engine run cooler by restricting flow. That is an old wives tale that has been disproven by scientific testing. Higher flow = lower, more consistant temps in the heads, reduces steam pockets and reduces detonation. Proceed acordingly. ![](/ubbthreads/images/graemlins/Twocents.gif)
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#1110961
11/12/11 06:12 AM
11/12/11 06:12 AM
Posts: 2,128 sweden
sshemi
sweden
Is that really a fact? I believe that if water flows slow through the rad it will be cooler entering the motor.
Btw i have always used a stat with a mech pump. I even used a stat on my hemi with elec pump seemed to work but got too little run time to say for sure
