Performer RPM and stock throttle cable. Will it work? #1110555
11/09/11 10:19 PM
11/09/11 10:19 PM
Near Indy
slowpoke Offline OP
slowpoke  Offline OP
Near Indy
As it says, considering a Performer RPM intake on my 440 and wondering if the stock throttle cable/linkage will work as I know it's a tall intake. Holly carb...
Thanks!!!
Re: Performer RPM and stock throttle cable. Will it work? [Re: slowpoke] #1110556
11/09/11 10:44 PM
11/09/11 10:44 PM
IN
ahy Offline
ahy  Offline
IN
Worth trying but not likley. I'm running an M1 single plane and needed a longer cable. It took two tries to find one that fit and worked smoothly. A Lokar from Mancini did the trick.
Re: Performer RPM and stock throttle cable. Will it work? [Re: ahy] #1110557
11/09/11 10:51 PM
11/09/11 10:51 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
We have the stock cable on my sons Dart. It is a low block (400) and uses the Performer RPM. And the stock cable is working fine. Ron
Re: Performer RPM and stock throttle cable. Will it work? [Re: slowpoke] #1110558
11/09/11 10:54 PM
11/09/11 10:54 PM
Thanks!!!
What year and body stlye was the car and what motor did it have in it originally with the throttle cable your wanting to use? If it was a four barrel or six cylinder car it will probally work okay, if it was a V8 two barrel car, regardless of motor size, it probally won't Try what you got first
Re: Performer RPM and stock throttle cable. Will it work? [Re: Cab_Burge] #1110559
11/09/11 11:36 PM
11/09/11 11:36 PM
Vista, California
67Satty Offline
67Satty  Offline
Vista, California
On my '67 Satellite I swapped from a stock 318 2 barrel to a 440 with the Performer RPM intake. I tried ordering a new cable for a 440 car for it and that didn't work.
So I ended up using the cable from the 318 2 barrel and that's what I got to work. I did end up using the tall throttle cable bracket like Ron's son has on his Dart.
Re: Performer RPM and stock throttle cable. Will it work? [Re: 67Satty] #1110560
11/10/11 01:53 AM
11/10/11 01:53 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
My car still uses the stock 2-bbl throttle cable, and bracket with an RPM and 830 double pumper. I did, however, have to do some welding work to make this happen. I extended the ht. of the bracket about an inch (shown @ A), and extended the length of the kickdown rod a little, along with putting a bend in the rod to mate up to the stock location pin that the rod sits on (shown @ B).
(Pic worth 1000 words......)
Re: Performer RPM and stock throttle cable. Will it work? [Re: StealthWedge67] #1110561
11/10/11 01:56 AM
11/10/11 01:56 AM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
Mancini sells a taller bracket by AR Engineering that allows you to stay with the stock cable. I run it and it works great.
http://arengineering.com/throttlebracket/Tbracket/tbracketframe.html
1968 Pro-Touring Dodge Charger
*2011 Optima Ultimate Street Car Challenge Invitee
http://www.popularhotrodding.com/features/1203phr_1968_dodge_charger/index.html
Re: Performer RPM and stock throttle cable. Will it work? [Re: Viol8r] #1110562
11/10/11 02:38 AM
11/10/11 02:38 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
If anything you'll need to lift the purch from the factory height so it lines up with the throttle better, more or less a straight line, That adj bracket that was listed works great, but you also need to use the chrysler throttle bracket thats made for the holley or eddy if you don't already have this, I have never had to install a new cable "ever", they have a long enough throw, you just need to get it lined up & closer to its reach so it all works well & there will be plenty of throw for WOT.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: Performer RPM and stock throttle cable. Will it work? [Re: joedust451] #1110563
11/10/11 08:37 AM
11/10/11 08:37 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Use a /6 cable. It is the answer for one size fits all.
Re: Performer RPM and stock throttle cable. Will it work? [Re: Viol8r] #1110564
11/10/11 11:12 AM
11/10/11 11:12 AM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Re: Performer RPM and stock throttle cable. Will it work? [Re: Dcuda69] #1110565
11/10/11 06:27 PM
11/10/11 06:27 PM
Near Indy
slowpoke Offline OP
slowpoke  Offline OP
Near Indy
That kit from Mancini looks like the cats ***!!! Think I'll order that and see if my stock cable is long enough. If not will look at the slant 6 or Lokar.
Thanks everyone for the responses!!!
Re: Performer RPM and stock throttle cable. Will it work? [Re: slowpoke] #1110566
11/10/11 07:13 PM
11/10/11 07:13 PM
AndyF Offline
AndyF  Offline
Hughes Engines has the same throttle bracket kits as Mancini. Hughes might be closer to you.
www.hughesengines.com
http://www.hughesengines.com/Index/produ...mcgUHJvZHVjdHM=
Re: Performer RPM and stock throttle cable. Will it work? [Re: AndyF] #1110567
11/10/11 07:28 PM
11/10/11 07:28 PM
Near Indy
slowpoke Offline OP
slowpoke  Offline OP
Near Indy
Thanks for the info AndyF!
Re: Performer RPM and stock throttle cable. Will it work? [Re: Viol8r] #1110568
11/10/11 11:36 PM
11/10/11 11:36 PM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
The 318 cable will be the longest. The 440 cable is fairly short, and the HEMI is the shortest of all. A 440 six pak cable is a little longer, but not as the 318 (either will work for your app.).
Just general info on stuff I ran into over the years.
Re: Performer RPM and stock throttle cable. Will it work? [Re: DANA60] #1110569
11/11/11 01:27 PM
11/11/11 01:27 PM
Texas
70Runnerdude Offline
Texas
I remember a while back someone posted the various mopar throttle cables and their lengths with part numbers that you could buy new. Anyone have this info I lost it.
Thanks!
Re: Performer RPM and stock throttle cable. Will it work? [Re: 70Runnerdude] #1110570
11/12/11 12:59 PM
11/12/11 12:59 PM
Franklin Co. Illinois
runinonmt Offline
runinonmt  Offline
Got mine at O'Reilly's using a part number.
http://www.moparts.org/Tech/Archive/fuel/24.html
Ron
In sixty-five I was seventeen and running up one-o-one I don't know where I'm running now, I'm just running on Jackson Browne-Running On Empty
Re: Performer RPM and stock throttle cable. Will it work? [Re: runinonmt] #1110571
11/12/11 04:54 PM
11/12/11 04:54 PM
Near Indy
slowpoke Offline OP
slowpoke  Offline OP
Near Indy
That's awesome, thanks for the post!
