Page 3 of 3 1 2 3
Re: BOTTOM-END GIRDLE KIT??? [Re: bcrproducts] #1109458
11/10/11 10:51 PM
11/10/11 10:51 PM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
Had not seen that kit yet sorry. Descent copy of our design. Had to happen sometime. Our design will be back out soon and is sustantially different in the way it works.. Once ours is back out I would hope out of respect, Moparts members and others will buy ours and not a copy of what we designed without any consent. Hopefully you all buy legit software and not pirated versions as well. I can understand right now to build a motor you all want something that works.
Greg
Everybody copy's somebody. Here is a page from
the 1964 Don Garlits racing catalog. He was
selling Hemi Chrysler main supports way back over
48 years ago. I'm sure he copied someones idea
and just made it better.
Snap your neck, mega G-force launch, is all I want!
Re: BOTTOM-END GIRDLE KIT??? [Re: BDS871Cuda] #1109459
11/10/11 11:12 PM
11/10/11 11:12 PM
State of Corruption
camdog440 Offline
camdog440  Offline
State of Corruption
That Garlit's piece looks stout.
It must have been for the 354/392 hemis... in '64 he was still running the old hemi.
Re: BOTTOM-END GIRDLE KIT??? [Re: bcrproducts] #1109460
11/10/11 11:40 PM
11/10/11 11:40 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
Greg
I don't know how long ago you made yours but the guy that makes them for Mancini made one for us for the motor we did for my brother was about 6-7 years ago. We found a couple of flaws in that got corrected on the second one. At that time I was never aware that there even was anything like it out there . . Jake
JAKES AUTOMOTIVE
Re: BOTTOM-END GIRDLE KIT??? [Re: camdog440] #1109461
11/11/11 07:31 AM
11/11/11 07:31 AM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
If you look, the crank centerline and the oilpan mounting surface are even. It's a lot easier to make than the later B/RB/Hemi set-up.
I've always wondered how well a plate of metal can absorb the crankforces that are applied laterally but apparently it helps.
Re: BOTTOM-END GIRDLE KIT??? [Re: BSB67] #1109462
11/11/11 11:16 AM
11/11/11 11:16 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I'd love to have all the test equipment to see exactly what the stresses & dynamics of a main cap are under operating conditions. However, my thoughts after talking w/ the machinist who prepped my last two blocks are:
1. The girdle is NOT expected to keep the caps from being pushed directly down.
2. The girdle helps add stability by keeping the main caps from "waiving around" due to the various directional loads placed on them.
Think of this like a flag pole that is unsupported at the end where the flag is being moved around by the wind. If the normally unsupported end of the flag pole was also attached to a stationary object, the "waiving around" will be reduced. Yeah, another over-simplified analogy on my part, but IMO it still makes sense.
Therefore, even the low-budget girdles should still add some level of improved bottom end durability, even if not the optimal (re)design of cap / girdle / block integration.
Re: BOTTOM-END GIRDLE KIT??? [Re: BradH] #1109463
11/11/11 05:22 PM
11/11/11 05:22 PM
Holly/MI
Holly/MI
OK, so, horizontally, not vertically relative to the crank centerline.
I like the theory behind why splayed 4 bolt set-ups work.
Re: BOTTOM-END GIRDLE KIT??? [Re: Dean_Kuzluzski] #1109464
11/12/11 10:34 AM
11/12/11 10:34 AM
Andrews,In. U.S.of A.
67_Satellite Offline
Thought they were splayed to spread the forces from the bolts out over a greater area of the block?
Re: BOTTOM-END GIRDLE KIT??? [Re: 67_Satellite] #1109465
11/12/11 12:02 PM
11/12/11 12:02 PM
Holly/MI
Holly/MI
I'll guess partially but not completely. The transfer of all the crank forces are not in one direction. One bank is going to send pulsations a different direction than the opposing bank.
Just like "cap walk" isn't just horizontally. It's more like the caps are bouncing within the elasticity of the bolts (or studs) and as the the crank transfers forces the caps walk/bounce accordingly absorbing pulsations within its limits until they break.
Or so I would guess.
Re: BOTTOM-END GIRDLE KIT??? [Re: BDS871Cuda] #1109466
11/12/11 12:06 PM
11/12/11 12:06 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
heres a pic of BCR's girdle/main caps assembly
Re: BOTTOM-END GIRDLE KIT??? [Re: smokinwoody] #1109467
11/13/11 03:52 PM
11/13/11 03:52 PM
Clinton Twp... north of Deetro...
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
That BCR set-up is one STOUT looking piece!
Re: BOTTOM-END GIRDLE KIT??? [Re: Labratt] #1109468
11/13/11 04:16 PM
11/13/11 04:16 PM
That's the unit I have as well.
Re: BOTTOM-END GIRDLE KIT??? [Re: 69darthulk] #1109469
11/13/11 08:13 PM
11/13/11 08:13 PM
ONTARIO,CANADA
604 Hemi GTX Offline
ONTARIO,CANADA
I used the kit from 440 source. Low deck making around 700hp and am very happy with how it's holding up. Had the machine shop set it up and line hone it. They were nice enough to mark the shims for when I reasembled it.
http://store.440source.com/Main-Stud-Girdles/products/135/
Just wondering how the 440 source main girdle would work with aluminum main caps. I see he sell the kit, just wondering
Kevin
Re: BOTTOM-END GIRDLE KIT??? [Re: smokinwoody] #1109470
11/13/11 11:24 PM
11/13/11 11:24 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
It's such a nice piece it's a shame to cover it up with the oil pan.
Re: BOTTOM-END GIRDLE KIT??? [Re: BradH] #1109471
11/14/11 12:59 AM
11/14/11 12:59 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Not being a machinist, I'm curious why you need to have the main caps align honed when switching from bolts to studs, considering the caps fit into the main registers and the hardware is just there to strap 'em down. Yeah, I know, that's an over-simplified view... but still.
IMO, The distortion issue of the extra torque value is minimal. The studs extra shank diameter vs the bolts shank diameter is what can kick the main registers out of skew. Ive seen it, you wouldnt think it could happen but it does.
The simple finger nail test will catch it. Now it catches , before it didnt.
Yeah, I know, thats's an over-simplified view... but still.
Re: BOTTOM-END GIRDLE KIT??? [Re: ] #1109472
11/14/11 02:09 AM
11/14/11 02:09 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
thats why I want one to replace the CRE unit that I have...mine uses the stock caps...I want the extra beef and I like the main caps going web to web adding to the rigidity..
Re: BOTTOM-END GIRDLE KIT??? [Re: rowin4] #1109473
11/14/11 11:53 AM
11/14/11 11:53 AM
Mo.
racerx Offline
racerx  Offline
Mo.
That is a pretty piece wonder what that setup would cost ya.
Re: BOTTOM-END GIRDLE KIT??? [Re: racerx] #1109474
11/14/11 11:57 AM
11/14/11 11:57 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
If i remember correctly I paid around 850 dollars for the main caps and girdle but I could be off a few bucks
Re: BOTTOM-END GIRDLE KIT??? [Re: joshking440] #1109475
11/14/11 12:20 PM
11/14/11 12:20 PM
Mo.
racerx Offline
racerx  Offline
Mo.
That is a nice pease..but if i was to do another bullet i'll just in vest that 850.00 in a new block.Speaking of blocks any testing made with the new b-block yet
Re: BOTTOM-END GIRDLE KIT??? [Re: racerx] #1109476
11/14/11 09:33 PM
11/14/11 09:33 PM
bcrproducts Offline
super gas
bcrproducts  Offline
super gas
They were $799.00 back when I was making them.That came with ARP main studs Arp studs fro the girdle and pan rails and all fasteners required in the bottom end build for the pan rails
Greg
Page 3 of 3 1 2 3
