Re: Tranny gurus later big block 727 part throttle kickdown
[Re: JohnRR]
#110894
08/28/08 08:43 AM
08/28/08 08:43 AM
Posts: 4,150 lewiston, ID
cornucopia
lewiston, ID
UH OH did I open a can of worms?
No , I have a thought in my head but I'm keeping it to myself at the moment ...
The thought in my head is the same as others here , it's a function of the VB , not the case .
and you don't even need the whole valve body to get the PTK...it's one small spool valve and a small, screw on housing. two screws and you can convert ANY valve body to PTK in less than 5 minutes. the slant six trannys got it first. around 1969 or so...I retrofit all my autos if they don't already have it.
[Re: cornucopia]
#110895
08/28/08 09:55 AM
08/28/08 09:55 AM
340dart4spd
Parts Problem
Parts Problem
It all comes back to me now....LOL
[Re: 340dart4spd ]
#110896
08/28/08 10:43 AM
08/28/08 10:43 AM
RapidRobert
& FYI there was an article way back about 727 failures that was traced to mixing & matching shafts/gears as it seems there were slight changes in spline count or shape of the splines. Kunkel will know. It came down to there were(3) different groups of years in the 70's that the rotating assemblies must be kept together & not mixed & matched. this isn't directly related to the Q but something to be aware of.
[Re: KillerBee]
#110899
08/28/08 03:44 PM
08/28/08 03:44 PM
Posts: 25,786 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The last post in the thread below has my rambling observations on the PTK retrofit: https://board.moparts.org/ubbthreads/show...rue#Post4623468Also, I would disagree that PTK isn't an asset to big block cars, while they may lug away in top gear just fine from low speed it's nice to have the more brisk acceleration of the lower gear.
