J BODY / SLANT 6 QUESTIONS #1108404
11/07/11 12:14 AM
11/07/11 12:14 AM
S.E.Ohio
Magnumguy Offline OP
S.E.Ohio
just bought an 81 Doba w/slant 6.
I want to disable the airpump, and it runs the a/c compressor (which works BTW), so can I route a belt around this? It looks like there's no adjustment if I remove the airpump. Didn't previous years not have the airpump? Do I need to change the whole pulley assembly?
Also, how do you adjust the idle mixture (where's the screw) and idle speed. It's a single barrel carb. What is the earliest 1 barrel carb that I can use w/o having so many hoses and stuff sucking off it?
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: J BODY / SLANT 6 QUESTIONS [Re: Magnumguy] #1108405
11/07/11 12:58 AM
11/07/11 12:58 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
To ditch the smog pump on my '84 D100, I picked up an idler pulley and made a bracket for it. The bracket is adjustable so I can tension the AC compressor belt.
For a 1bbl, I like the '68-'73 Holley 1920.
Your best option is upgrading to a Super Six 2 bbl using a Carter BBD.
My D100 had the original Holley 1bbl on it and got 18mpg@65mph. Going to a BBD, along with a '76 D150 head pipe (no Cats), got it up to 20mpg@65mph.
Re: J BODY / SLANT 6 QUESTIONS [Re: B5 Bee] #1108406
11/07/11 12:55 PM
11/07/11 12:55 PM
S.E.Ohio
S.E.Ohio
Thanks so much!! Appreciate the tips!!
