02 neon door handles #1108167
11/06/11 05:22 PM
11/06/11 05:22 PM
PA
maxwedge1 Offline OP
PA
got a couple of sticking door handles.
how do you access the linkage?? i only see 1 screw in the door panel and none on outside of door and dont want to start prying on plastic without some idea of were to start.
Re: 02 neon door handles [Re: maxwedge1] #1108168
11/06/11 08:14 PM
11/06/11 08:14 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
Re: 02 neon door handles [Re: maxwedge1] #1108169
11/06/11 08:25 PM
11/06/11 08:25 PM
Slantytown
DUFFMAN Offline
Ask And Ye Shall Receive
DUFFMAN  Offline
Slantytown
There are 2 more;
1. Behind the inside door handle. There is a plastic cover that needs to be removed to reveal it.
2. In the "cove" of the arm rest.
3. I assume you found the one in triangular area near the mirror.
That's it, the rest is clips. Luckily if you do break the panel there are lots of Neons in the JY thanks to the teens who wreck them.
No longer taking $h!t from anyone!
