MCH Eddy RPMs Flow Sheet? #1108004
11/06/11 11:50 AM
11/06/11 11:50 AM
tboomer Offline OP
tboomer  Offline OP
Anyone here have a flow sheet from Jeff@ Modern that they could post? I want to print one off for a buddy of mine that doesn't have a computer..Thanks!! Ted
Re: MCH Eddy RPMs Flow Sheet? [Re: tboomer] #1108005
11/06/11 12:12 PM
11/06/11 12:12 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Re: MCH Eddy RPMs Flow Sheet? [Re: S/ST 3040] #1108006
11/06/11 12:21 PM
11/06/11 12:21 PM
tboomer Offline OP
tboomer  Offline OP
Thanks,Vic...But all I see is a red x..
Re: MCH Eddy RPMs Flow Sheet? [Re: tboomer] #1108007
11/06/11 12:25 PM
11/06/11 12:25 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
I see a flow sheet.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: MCH Eddy RPMs Flow Sheet? [Re: tboomer] #1108008
11/06/11 12:46 PM
11/06/11 12:46 PM
Over here
Big Block Dart Offline
Over here
Re: MCH Eddy RPMs Flow Sheet? [Re: HemiRick] #1108009
11/06/11 12:56 PM
11/06/11 12:56 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Red X here as well! Memory says they flow about 300 @ .500
310 @ .550
315 @ .600 With the 2.14 valve.
325 @ .600 with the 2.19 valve.
Re: MCH Eddy RPMs Flow Sheet? [Re: Sport440] #1108010
11/06/11 03:33 PM
11/06/11 03:33 PM
Clinton Twp... north of Deetro...
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
Mike..Jeff's going to CNC port my Eddy's over the winter. You think going the 2.19 intake route would work for my car? Would it be worth the additional 10cfm? Thanks! Randy.
Re: MCH Eddy RPMs Flow Sheet? [Re: Labratt] #1108011
11/06/11 03:45 PM
11/06/11 03:45 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
324.5 at .600 int
230.8 at .600 exh
Sorry, i tried to attach my numbers sheet but it wouldn't work.
These are for rpm's with stock valves.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: MCH Eddy RPMs Flow Sheet? [Re: deaks] #1108012
11/07/11 10:38 AM
11/07/11 10:38 AM
Iowa
jon01 Offline
jon01  Offline
Iowa
What do they charge to CNC them?
Re: MCH Eddy RPMs Flow Sheet? [Re: Labratt] #1108013
11/07/11 06:19 PM
11/07/11 06:19 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Randy, upgrade to the 2.19's the added flow at low lift is just as important as peak. MORE important if you ask me.
Jeff
69 GTX 68 Road Runner
Re: MCH Eddy RPMs Flow Sheet? [Re: jon01] #1108014
11/07/11 07:07 PM
11/07/11 07:07 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
email Jeff and he will give you a price, i bought the heads from Jeff about 2 yrs ago, so his price might be different now.
The biggest jump in performance i've had from one change.
Mick
best 60ft 1.36
Re: MCH Eddy RPMs Flow Sheet? [Re: JERICOGTX] #1108015
11/07/11 08:38 PM
11/07/11 08:38 PM
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
Thanks,Jeff! I'll discuss it with Jeff shortly! The cost to do it is a BIG factor,though! I'm already having to break into my "Piggy Bank" paying for a new paint job,and getting the heads CNC'd!
Re: MCH Eddy RPMs Flow Sheet? [Re: deaks] #1108016
11/07/11 08:54 PM
11/07/11 08:54 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
324.5 at .600 int
230.8 at .600 exh
Mick
is this a stock port or max wedge ?
1.39 9.85 - 137 mph
Re: MCH Eddy RPMs Flow Sheet? [Re: Ari440] #1108017
11/08/11 09:43 AM
11/08/11 09:43 AM
tboomer Offline OP
tboomer  Offline OP
Thanks for the info,guys! I will pass it on!!
Re: MCH Eddy RPMs Flow Sheet? [Re: Ari440] #1108018
11/08/11 11:11 AM
11/08/11 11:11 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
324.5 at .600 int
230.8 at .600 exh
Mick
Ari
I believe it is stock port, it is definitely stock valve sizes.
Mick
