Transmission mount vibration UPDATE #1107182
11/04/11 08:22 PM
11/04/11 08:22 PM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
Just wanted to let ya all know it's amazing what a correct, good quality transmission mount will do. Took out that hacked up trans mount and installed a Schumacher "conversion" mount. Fit perfectly. No vibration. So, worn out and ill fitting mounts will cause bad vibrations. Sounds like a song.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: Transmission mount vibration UPDATE [Re: Junky] #1107183
11/04/11 10:17 PM
11/04/11 10:17 PM
are they harder than OE
Re: Transmission mount vibration UPDATE [Re: RapidRobert] #1107184
11/05/11 02:56 AM
11/05/11 02:56 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Glad to hear you got it fixed. Ron
Re: Transmission mount vibration UPDATE [Re: RapidRobert] #1107185
11/05/11 01:09 PM
11/05/11 01:09 PM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
Yes, it's polyurethane, harder than rubber. I was under the impression that it would transfer some vibration because of the harder material. But I cannot detect that it does. The vibration is gone. The mount fit perfectly. Very nice product. Schumacher also has excellent service. Here's their web site.
