Stripping paint from a hood #1107054
11/04/11 01:23 PM
11/04/11 01:23 PM
Metro Detroit
1970RT Offline OP
1970RT  Offline OP
Metro Detroit
I need to have a hood blasted so I can have it painted. I have heard sheetmetal parts are prone to distorting with certain types of media such as sand. What is the best type of blast media to use on a hood in order to keep the metal as straight as possible?
Re: Stripping paint from a hood [Re: 1970RT] #1107055
11/04/11 02:18 PM
11/04/11 02:18 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
plastic, soda or even walnut shells are fine for panel blasting. shoot at an angle, and keep it moving, and the distortion or heat build up shouldnt be an issue. chemical stripping is an option, if you can deal with the cleanup, or know a chemical stripping place.
Re: Stripping paint from a hood [Re: 1970RT] #1107056
11/05/11 03:34 AM
11/05/11 03:34 AM
OHIO
THE GLASS MAN Offline
OHIO
I have a 68 Dodge Dart with a metal flake paint job. I used a real good power washer. Yep I used water ! Nobody believes it except the rental company that loaned me the washer and their yard. Monday morning they came in and metal flake was every where.
