At what point do you need a rear sway bar and does #1106610
11/03/11 01:33 PM
11/03/11 01:33 PM
TN
SCATPACK 1 Offline OP
TN
#1 At What horsepower level would you need a sway bar in the rear with a 4 link car?
#2 Does it matter if the sway bar is in front of or behind the rear end housing?
#3 Does it have more effect if it is in front where the bars are atached or in the rear where the shock attaches?
#4 Do you install any preload or is that a car by car set up?
Old Geezer Racing
Re: At what point do you need a rear sway bar and does [Re: SCATPACK 1] #1106611
11/03/11 03:03 PM
11/03/11 03:03 PM
PA
moparacer Offline
moparacer  Offline
PA
#1 doesnt really matter what ET you are running a "anti roll bar" if set up correctly will help any car.
#2 no it can go in front or behind. Its only meant to keep the rear end s square in the chassis.
#3 no shouldnt make any difference but I always attach them to the housing.
#4 In a 4 link setup I NEVER try to preload the anti roll bar. I set the preload with the 4 link then after that is set I zero preload the anti roll.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: At what point do you need a rear sway bar and does [Re: moparacer] #1106612
11/03/11 04:18 PM
11/03/11 04:18 PM
TN
TN
Good info
Old Geezer Racing
