differences in 489 housings #1106418
11/02/11 10:51 PM
11/02/11 10:51 PM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
Was a special housing used for the sure-grip assembles? My car came with 2.76 open gears. The housing is noticably different then the replacement center section I have.(I'm going to use a 3.23 sure-grip...optional in 73)
Here is a picture of what's supposed to be an Oct 72 built center section.(3.55 gear) https://board.moparts.org/ubbthreads/upload2/6435961-SureGripMarkings001.jpg
Here's my original Oct 72 built center section. You can see that there is a cast pad in the center towards the top. The area under the pinion snubber has less material then the other housing. Mine has a small 9 cast into it that is facing right side up. The other housing has a large 9 on its side. There are other differences in the ribbing and the casting numbers toward the pinion.
I've got another picture of a 73 Challenger with 3.55 gears and the housing is the same as the first picture.
Re: differences in 489 housings [Re: burdar] #1106419
11/03/11 12:20 AM
11/03/11 12:20 AM
Howell, Michigan
Hemidavey Offline
Hemidavey  Offline
Howell, Michigan
Chrysler has more than one plant that made castings, just as they have many assembly and engine plants.
Re: differences in 489 housings [Re: burdar] #1106420
11/03/11 02:17 AM
11/03/11 02:17 AM
Washington
19cuda73 Offline
19cuda73  Offline
Washington
Darren here is a shot of the unit that came out of my car it has the 9 but no pad up area like the one in your picture. It is an Oct 72 car as well..
1966 Charger 383 4 speed (Black with Red interior)
1973 Cuda 340 4 speed (Lemontwist)
1972 Corvette
Re: differences in 489 housings [Re: Hemidavey] #1106421
11/03/11 06:59 AM
11/03/11 06:59 AM
www.mmcdetroit.com
MMC Detroit Offline
MMC Detroit  Offline
www.mmcdetroit.com
That is exactly the slight difference .
MMC/ ICCA Detroit. The Motor City or where ever there is Mopars
Re: differences in 489 housings [Re: MMC Detroit] #1106422
11/03/11 05:03 PM
11/03/11 05:03 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
With some (all?) later 489 cases, you have to grind some material out of the case to make higher numerically gears fit.
Re: differences in 489 housings [Re: burdar] #1106423
11/03/11 06:07 PM
11/03/11 06:07 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
To answer your question , no there was not a special casting for sure grip rears .
Re: differences in 489 housings [Re: JohnRR] #1106424
11/03/11 06:12 PM
11/03/11 06:12 PM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
