big block 1974 charger auto drive shaft lenght ? #1106221
11/02/11 08:27 PM
11/02/11 08:27 PM
dracut mass usa
sparcy Offline OP
sparcy  Offline OP
dracut mass usa
my 1974 charger 318 auto car , now a 383 auto car what is the lenght of a big block auto drive shaft weld to weld ?? how close is the small block drive shaft ?? I CUT THE FACTORY ENGINE MOUNTS IN HALF , TO GET THE ENGINE IN THE CAR CAN ANYONE TELL ME HOW FAR BACK THE ENGINE IS FROM THE RADIATOR SUPPORT IN A 1973 OR 74 BIGBLOCK CAR ?? OR A PICTURE OF THE LEFT SIDE CLY HEAD OVER THE STEERING BOX TO SEE HOW CLOSE I AM . THANKS
IF YOU ARE NOT WRECKING STUFF YOU ARE NOT LEARNING !
Re: big block 1974 charger auto drive shaft lenght ? [Re: sparcy] #1106222
11/02/11 10:28 PM
11/02/11 10:28 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Take the trans yoke end of the shaft and push it into the trans until is stops.Pull it back out 1/2' to 3/4' and then measure from the center of the Ujoint to the center of the ujoint area in the rearend yoke, That is the correct way to measure for a driveshaft. Do it any other way and you will be having the shaft done again. That gets pretty darn expensive.
