stevemorrisengines
#1106176
11/02/11 07:18 PM
11/02/11 07:18 PM
Posts: 7,506 Az
Crizila
Az
Anyone running a D1sc system one their small block? I would be interested in your opinion and what the system actually consists of ( hard parts ). How much power are you making with it? Install troubles - how complete is the system? Thanks, John
Fastest 300
Re: stevemorrisengines
[Re: Crizila]
#1106177
11/03/11 12:30 PM
11/03/11 12:30 PM
Posts: 2,260 IL
furious70
IL
Big cam in the 408 not cutting it anymore John? Too bad you're not up here still, we could take you turbo!
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: furious70]
#1106178
11/03/11 05:10 PM
11/03/11 05:10 PM
Posts: 7,506 Az
Crizila
Az
Altitude sickness Jeremy . My choices are: more inches, drop 1200 lbs, or puff it. Seriously looking at the last two choices - and the weight loss would involve a different ride.
Fastest 300
[Re: Crizila]
#1106179
11/03/11 06:04 PM
11/03/11 06:04 PM
Posts: 2,260 IL
furious70
IL
you've got a fully equipped shop, skip the supercharger and build a turbo setup, shouldn't be hard to fit a T6 single in that whale.
[Re: furious70]
#1106180
11/03/11 06:33 PM
11/03/11 06:33 PM
Posts: 214 Colo Springs, CO
DconD100
Colo Springs, CO
I've got the old P600B on the 408 in my dart. It only makes 6lbs of boost (compared to 10lbs with the 360), spinning to the max rpm of the supercharger. It runs the same 10.52 @ 127mph best with either engine. At 3600 pounds, that shows about 560hp on the Moroso slide chart(which is over 750 at sealevel...not saying it would necessarily do that though). The D1SC has 350 more cfm flow, and that's one of the one's that I am looking at upgrading to. My set up is from SDCE, so it mounts on the passenger side. I think the Morris setup will be easier to install. After messing with some turbo stuff though, I think that is the way to go!
Pump Gas Small Blocks Rock!
11.53 @ 116mph E85 408 at 8500 ft da,
3605 pound truck, 3.91s, street driven
[Re: Crizila]
#1106182
11/08/11 03:41 PM
11/08/11 03:41 PM
Posts: 2,260 IL
furious70
IL
if you use a 2 step or something it should be consistent. If it's consistent now and that's your main objective then you don't need to change anything, right?
