was thinking more like this:
ok my paint skills are entierly useless but the thought was to use a bigger radiusbend to be able to get the pipe under the forwardbars and still stay above the #1 tube,at the cost of correct lenght but it will flow better than a tighterradiusbend anyway so i dont think it would cost any performance.
you may not need to cut the pipe back as much as in the drawing but it gives you an idea.
im useless at explaining things like this and pretty crapy at making stuff in paint but im not all that useless at bending,routing and welding tubing i hope at least
