need some weatherstrip guidance #1105353
11/01/11 07:09 PM
11/01/11 07:09 PM
albemarle, NC
dusterbd13 Offline OP
albemarle, NC
ok, 70 duster. all new weatherstrip during restoration.
ive got some problems at all 4 panels of side glass.
on the wing windows: the front seals to the weatherstripping (up near the doors) but the back has a 1/16 or so gap (back by the latch). similar on both sides. is there an adjustment or solution for this? i cant shim the latch to glass screw, as it would make the gap worse, not better.
on the door glas:
at the back of the glass, there is a 1/4 to 3/8 gap along the whole wing window section. howls like a banshee going down the highway. also gaps intermittently along the uppermost portion of the roofrail. also has a gap down by the door to a-pillar, but it seals up again a little ways up the a-pillar. the glass cant be THAT wavy.
i was wondering on this if anyone has some CLEAR pictures on howthis piece of weatherstripping should look when installed. drawings are OK too. also, where should the weatherstripping be glued in at around the window? currently i just have it pressed into the chanel and held in place by friction and magic.
heres the best pictures i could get of what im talking about ( i apologize, but ive apparently been incapable of taking a good picture for the last two weeks. )
i could really use some pointers on fine tuning the weatherstripping before i try adjusting my windows for the 3,467th time to stop the leaking and wind noise.
then ill feel better about getting slight tint applied (i live in the south. an all black interior gets HOT in the summer in front of work)
michael
Michael Crawford CSP 1970 plymouth Duster back under construction: http://www.pro-touring.com/showthread.ph...ouring-makeover 1964 el camino beater shop truck 96403-project-drivabeater-2-0-64-el-camino-this-time
Re: need some weatherstrip guidance [Re: dusterbd13] #1105354
11/03/11 08:09 PM
11/03/11 08:09 PM
albemarle, NC
albemarle, NC
just bumping. hoping to get some help. the wind whistles and water leakage are driving me buggy.
Re: need some weatherstrip guidance [Re: dusterbd13] #1105355
11/04/11 02:01 AM
11/04/11 02:01 AM
Have you treid adjsuting the windows as far as in and out movement(side to side) on the adjusters in the doors If not try that, you can also adjust the angle of the windows front to back to make them fit better in the back also. What brand seals did you buy? I did my 1971 Duster several years back and have no wind noise at all, a lot of exhaust noise but no wind noise, even above 100 MPH at the track
