black on accesory panel and vents 69 b-body #1104590
10/31/11 09:49 AM
10/31/11 09:49 AM
PA
BTTG Offline OP
BTTG  Offline OP
PA
anyone know of a rattle can paint option that faithfully reproduces the black paint used on the accessories panel (headlights, dimmer, wiper, washer on a non-ralley dash), center A/C vent bezel and side A/C vent bodies for a 69 b-body? Not sure if all those are pot metal, but the paint on all is pretty unique and not sure if that it due to the paint or the underlying metal?
Re: black on accesory panel and vents 69 b-body [Re: BTTG] #1104591
10/31/11 10:24 AM
10/31/11 10:24 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
center vent bezel and side vents are suede. same as the dash frame and steering column jacket
untouched side vent - 1969 B-body
Re: black on accesory panel and vents 69 b-body [Re: gtx6970] #1104592
10/31/11 10:52 AM
10/31/11 10:52 AM
Utah
E
Eagleone1983 Offline
E
Utah
I just used semi gloss rustoleum black and an ultra fine white paint marker for the lettering. Looks great and I think it is correct though that doesn't really matter much to me.
Re: black on accesory panel and vents 69 b-body [Re: Eagleone1983] #1104593
10/31/11 11:14 AM
10/31/11 11:14 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I used SEM satin black Trim Paint on my A/C vents on my '68 road runner..............my dash was green so it didn't have to match anything...and it looked pretty good if I do say so myself
MikeR
Re: black on accesory panel and vents 69 b-body [Re: A12] #1104594
10/31/11 11:23 AM
10/31/11 11:23 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Oh and I think someone makes a "flat" Trim Paint that looks like the flat (egg shell) dash finish like what Bill is showing above but it doesn't have the "egg shell" grain, maybe take a sponge dip it in some paint and splatter it on first let it dry and then hit it with some flat paint
Re: black on accesory panel and vents 69 b-body [Re: gtx6970] #1104595
11/07/11 10:23 AM
11/07/11 10:23 AM
PA
BTTG Offline OP
BTTG  Offline OP
PA
OK. got it for the vents, but is the accessory panel suede (textured) as well? also is it flat? picture of panel attached..... last point are the accessory switch openings outlined in white as well originally or is only white for lettering?
see that rustoelum has a textured black that is claimed to produce a suede type finish and was going to use it on the side/center vents, but wanted to confirm its appropriateness for use for the accessory panel.
Re: black on accesory panel and vents 69 b-body [Re: BTTG] #1104596
11/07/11 10:31 AM
11/07/11 10:31 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I've never seen the switch openings outlined in white, at least not on a '68 road runner or '69 rr or GTX....but maybe that's just me
Re: black on accesory panel and vents 69 b-body [Re: A12] #1104597
11/07/11 07:31 PM
11/07/11 07:31 PM
lancaster, new york
macmic87 Offline
macmic87  Offline
lancaster, new york
also the correct panel for 1969 will have the texture already cast into it.
