POWER TO MANUAL STEERING IN STREET/STRIP GTX? #1104446
10/31/11 01:55 AM
10/31/11 01:55 AM
Clinton Twp... north of Deetro...
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Seriously thinking of switching to a manual steering box in my '69' GTX over the winter. Any suggestions on which unit to purchase would be helpful!
Re: POWER TO MANUAL STEERING IN STREET/STRIP GTX? [Re: Labratt] #1104447
10/31/11 08:35 AM
10/31/11 08:35 AM
Southern Maryland
preddy Offline
preddy  Offline
Southern Maryland
I did the same thing a few years ago. I bought one of these adapters:
http://chucker54.stores.yahoo.net/mamastad.html
I also bought a used manual steering box and it was a simple swap.
If you wanted to buy a new manual steering box, I would consider checking out FirmFeel. A few years ago, I bought a quick ratio power steering unit from them and I really liked it. I would think their manual steering boxes are pretty good too.
http://www.firmfeel.com/manualst.htm
Re: POWER TO MANUAL STEERING IN STREET/STRIP GTX? [Re: preddy] #1104448
10/31/11 11:28 AM
10/31/11 11:28 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I used the same adapter. And I bought a used steering box off ebay. It was in perfect shape. Ron
Re: POWER TO MANUAL STEERING IN STREET/STRIP GTX? [Re: 383man] #1104449
10/31/11 11:46 AM
10/31/11 11:46 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks for the info,Preddy...Ronnie! I just checked out the Firm Feel link,and the faster ratio units(20:1 and 16:1)are N/A! I'll be looking for a NEW,or RE-BUILT unit. Don't really want to pay the $300.00 asking price of the FF STOCK 24:1 unit. If anyone knows where I can find one at a GOOD price,please let me know! BTW...Ron,how stiff does the steering feel at low speeds? I would think at high speeds it feels a lot more stable! Thanks! Randy B.
Re: POWER TO MANUAL STEERING IN STREET/STRIP GTX? [Re: Labratt] #1104450
10/31/11 12:20 PM
10/31/11 12:20 PM
Get-X Offline
Get-X  Offline
I used the same adapter as Ron and Preddy, works great. I personally just bought a used box from a member here on Moparts (thanks Mike!) that came with the box in great shape, pitman arm and drag link with the idler still there and the mounting bolts for $100! The production boxes are feather light and wear like iron.
'65 Belvedere
'68 GTX
'57 Dodge pickup
Re: POWER TO MANUAL STEERING IN STREET/STRIP GTX? [Re: Get-X] #1104451
10/31/11 02:27 PM
10/31/11 02:27 PM
Pittsburgh, Pa
Jeff_383 Offline
Jeff_383  Offline
Pittsburgh, Pa
I have that adapter. If you want to buy it I would easily let it go.
Re: POWER TO MANUAL STEERING IN STREET/STRIP GTX? [Re: Labratt] #1104452
10/31/11 03:13 PM
10/31/11 03:13 PM
long time lurker, short time p...
P
PorkyPig Offline
PorkyPig  Offline
P
Saves about 40 pounds, helps build big forearms, steers like a tank at low speeds, doesn't feel much different at high speeds.
The trick is to find a cheap used standard gear like I did (about $50) so most of the cost is buying the adapter.
Re: POWER TO MANUAL STEERING IN STREET/STRIP GTX? [Re: PorkyPig] #1104453
10/31/11 03:24 PM
10/31/11 03:24 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Actually I was surprised at how easy my 63 steers. It is much easier then I thought it would be and I like the manual steering as you can feel the road better. The only time you need to use 2 hands on my 63 is when parallel parking. But it really is so easy to steer. Ron
Re: POWER TO MANUAL STEERING IN STREET/STRIP GTX? [Re: Labratt] #1104454
10/31/11 03:29 PM
10/31/11 03:29 PM
Alberta Canada
StrokerAspen Offline
Alberta Canada
Hm.... I just put a manual box in with the manual steering rod. all stock junk. I think it was out of an A-Body, as I had to buy a new pitman arm for it to work in the Aspen.
-Kenny
Re: POWER TO MANUAL STEERING IN STREET/STRIP GTX? [Re: 383man] #1104455
10/31/11 04:17 PM
10/31/11 04:17 PM
Get-X Offline
Get-X  Offline
I agree 100 percent. Chrysler manual steering is easy to steer. GM manual is a lot tougher to steer and really hard to parallel park with.
'65 Belvedere
'68 GTX
'57 Dodge pickup
Re: POWER TO MANUAL STEERING IN STREET/STRIP GTX? [Re: Get-X] #1104456
10/31/11 05:59 PM
10/31/11 05:59 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I've got the same adapter setup, only mine is the goofy older one that was originally used on a B van, that you had to use a manual coupler with. That was before Mancini made their version, with the power coupler spline setup. That stuff was alot more difficult to find before the internet! As a result of getting that, I bought a few nos manual couplers for spares, figuring nobody would reproduce them. The box is a good used one that I think I got at the Nats about a million years ago.
Rich H.
Esse Quam Videri
Re: POWER TO MANUAL STEERING IN STREET/STRIP GTX? [Re: ZIPPY] #1104457
10/31/11 06:48 PM
10/31/11 06:48 PM
Plymouth, MI
Blusmbl Online content
Blusmbl  Online Content
Plymouth, MI
Used is fine, I swapped to one in my Charger and had no objections at all to how it steered, I liked it over the overboosted power assist they came with stock.
I had an A-body box and Mancini coupler, just have to swap the pitman arm, and I also thought the A-body piece uses bushings instead of bearings, but don't quote me on that.
Re: POWER TO MANUAL STEERING IN STREET/STRIP GTX? [Re: Blusmbl] #1104458
10/31/11 08:09 PM
10/31/11 08:09 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i tried a cr box in my 69 GTX and it took all the fun out of street driving it.gittin in and out of gas pumps and drive ways was a real chore for me.with the stock manual box its not too bad but did take some gettin used to from the PS.
Re: POWER TO MANUAL STEERING IN STREET/STRIP GTX? [Re: bonefish] #1104459
10/31/11 11:23 PM
10/31/11 11:23 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
I have a couple of good manual boxes, I'm looking for a good PS box for my wifes Cuda. Just in case your interested.
Re: POWER TO MANUAL STEERING IN STREET/STRIP GTX? [Re: Blusmbl] #1104460
11/01/11 06:29 AM
11/01/11 06:29 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
The manual boxes from 6 cyl cars have bushings,V8 cars have bearings.I have manual steering in both of my cars (A and B body with big block) and they steer great.
Nautilus Racing-
Re: POWER TO MANUAL STEERING IN STREET/STRIP GTX? [Re: Labratt] #1104461
11/02/11 01:56 AM
11/02/11 01:56 AM
murfreesboro, TN
Q
Qbird Offline
Qbird  Offline
Q
murfreesboro, TN
The adapter thing is a total scam. I've taken several power and manual steering columns apart over the years, and the internal shaft (sliding part) is THE SAME! Chrysler used "plastic rivets" to create just enough drag on the sliding part of the shaft to keep it from flopping around while being handeled on the assembly line. Those rivets don't penetrate the sliding shaft at all...they just poke through holes and rub against it.
If you take a P/S steering shaft, and pull the center all the way out, it would actually touch the steering box itself, and STILL have 100% engagement with outer, or driving part of the shaft.
Re: POWER TO MANUAL STEERING IN STREET/STRIP GTX? [Re: Qbird] #1104462
11/02/11 09:40 AM
11/02/11 09:40 AM
Wi.
old_racer Offline
old_racer  Offline
Wi.
this may be true but the splines on the manual box are different than the p/box so the coupler still needs to be changed.
Re: POWER TO MANUAL STEERING IN STREET/STRIP GTX? [Re: old_racer] #1104463
11/02/11 12:33 PM
11/02/11 12:33 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thank You for the info,gentleman! More than a FEW people have told me the coupling adapter IS needed! Now...to find a GOOD,TIGHT box to install!
Re: POWER TO MANUAL STEERING IN STREET/STRIP GTX? [Re: Labratt] #1104464
11/02/11 12:43 PM
11/02/11 12:43 PM
Ohio
Todd Offline
Todd  Offline
Ohio
Why not install one of these babies? IIRC I got this one from Speedway motors. Was around 30 bucks.
Re: POWER TO MANUAL STEERING IN STREET/STRIP GTX? [Re: Labratt] #1104465
11/02/11 04:01 PM
11/02/11 04:01 PM
Lenox, MI
gj69charger Offline
gj69charger  Offline
Lenox, MI
Randy. I made that switch several years ago. I went with a Flaming River box with the adapter. I like it. B bodies are tough to steer until you get them rolling.
