Timing cover and pointer #1104373
10/30/11 10:42 PM
10/30/11 10:42 PM
NY
Beep Beep Offline OP
NY
I am looking at purchasing a steel timing cover from 440 source, I have a choice between a fixed timing pointer for $6 or the adjustable for $40 from 440 source. Which one should I purchase for my BB? Thanks
Re: Timing cover and pointer [Re: Beep Beep] #1104374
10/31/11 02:27 AM
10/31/11 02:27 AM
is it possible for you to post some pics. You can remark the dampener but it's nice to just reference the OE mark especially with a dial back. If the adjustable one ain't a rube goldberg flimsy deal I'd consider it and you do wanna find exact TDC to start with
Re: Timing cover and pointer [Re: RapidRobert] #1104375
10/31/11 10:52 PM
10/31/11 10:52 PM
NY
NY
Re: Timing cover and pointer [Re: Beep Beep] #1104376
11/01/11 10:06 AM
11/01/11 10:06 AM
Nothing flimsy about the adj one in the 2nd pic but that is alot of money. I'd prob get the fixed one & find exact TDC & paint a new white line if need be then spring for the adj one later if I was not happy with it. You can make additional white marks using the tab as a ruler and if you dont have a dialback, 2 marks for initial and total will suffice
